Right seal leak driving me INSANE
  • Filter
  • #31
    Originally posted by motoman View Post
    They come with a cup that they set in for installation. use approx. same diamater wuuden/plastic mallot on the CUP to drive seal in. If you haven't been using the cup they set in, THAT is why they're leaking. ANY mior distortion(cocked to one side a bit on initial starting instalation or not using the cup provided to keep distortion from hapening.........not using the install cup WILL distort that thin metal enough. Oil has better visibilaty than you, and finds its way out.
    I read (somewhere) that the sleeve needs to be put in backwards on these bikes. That's what I did last time. Because of that I didn't use the cup but tapped it in with the mallet. It came out easy enough with a screwdriver so the inner edge may have been widened during installation.
    I also saw that someone had to dremel the outer edge after the installation part was removed. I did that but couldn't tell if it was actually required.
    So ANY suggestions will help. I don't want to buy a third sleeve.
    _________________________________________
    1981 XS1100SH (Lola) - Bright Cardinal Red
    Whatever Lola wants, Lola gets.. Don't mess with Lola.
    Mostly stock with a few minor upgrades
    1981 XS11000SH being used for parts (Sold off)
    Also have:
    2009 Harley Davidson FLSTC with over 120K miles. All mine.
    Currently traveling the country with an aluminum can in tow and a motorcycle in the truck bed in search of the perfect road.
    • #32
      Okay, I installed the new speedie sleeve making sure it's nice and even. I smeared the axle with a little RTV before hand. It mostly pushed it off. I also put it in backwards and polished it.
      I had to file down the outer edge of the sleeve to alow the seal to slide on without rolling the inner lip. Since the sleeve is backwards the installation ring left behind a very rough edge.
      I put RTV around the seal to hold it in place.
      I've ridden over 200 miles without any leaking so I'm hopeful. Just in case, I will have two new replacement seals with me at xsse.
      Thanks!
      Also have:
      • #33
        I've now ridden well over 2K miles without any leaking so I'm calling it fixed. :-)
        Also have:
        • #34
          Nicely done in your post #32.
          • #35
            Rich
            Glad it worked I think with 2000 miles you've got it fixed.
            Rodan
            1980 G Silverbird
            1198 Overbore kit
            Grizzly 660 ACCT
            Barnett Clutch Springs
            R1 Clutch Fiber Plates
            122.5 Main Jets
            ACCT Mod
            Mac 4-2 Flare Tips
            Antivibe Bar ends
            Rear trunk add-on
