Right seal leak driving me INSANE
  • RichV
    • May 2013
    • 374
    • Everywhere
    Originally posted by BA80
    Drain hole?????
    Check and make sure your crank case vent isn't plugged or obstructed in any way.
    The hole in the bottom of the seal housing. It passes through to the crankcase.
    _________________________________________
    1981 XS1100SH (Lola) - Bright Cardinal Red
    Whatever Lola wants, Lola gets.. Don't mess with Lola.
    Mostly stock with a few minor upgrades
    1981 XS11000SH being used for parts (Sold off)
    Also have:
    2009 Harley Davidson FLSTC with over 120K miles. All mine.
    Currently traveling the country with an aluminum can in tow and a motorcycle in the truck bed in search of the perfect road.
      Interesting, I don't recall ever seeing that before, on ANYTHING.
      • RichV
        • May 2013
        • 374
        • Everywhere
        I actually didn't pay attention to it. I though it was a leftover in the case design.
        Also have:
          Thinking about though it does make sense. The oil being forced in that bearing insert would have to have someplace to go rather than just building pressure between the seal and case.
          • RichV
            • May 2013
            • 374
            • Everywhere
            Have you seen a hole like this cut in the seal housing? I agree the oil should go somewhere but in this case a non-OEM seal runs the risk of blocking this hole. That would cause pressure on the seal.
            Also have:
              You should be able to look at it and see if it's blocking it. Have you used the same seal (manufacturer and part #) each time you replaced it?
              • RichV
                • May 2013
                • 374
                • Everywhere
                I don't know. I got them from three different sources, all on the internet. Do you have a good source?
                Also have:
                • CaptonZap
                  • Jun 2010
                  • 1748
                  • Denver
                  Drain hole?????
                  Yeah, what he said.
                  CZ
                    I sent trbig a PM. I'm pretty sure he has the part # and a source.
                    • RichV
                      • May 2013
                      • 374
                      • Everywhere
                      Not plugged. Ventilation working fine.
                      Also have:
                      • RichV
                        • May 2013
                        • 374
                        • Everywhere
                        Thanks that will help. I have a good source for right seals but not the left.
                        Also have:
                          I've had good luck with the TCM double lipped seals. They don't ride in the same place on the crank the old ones did. Last time I ordered, I got several from this place... www.abxbearings.com Not much of a website and I can't even find them on there any more, but I just directed someone else to them recently and they still had them.. like 4-5 bucks a piece and shipping was $6 even with several ordered. Best bet is to just call them. Ask for Nicole.. she's a sweetheart. 713-957-1700 TCM part # 32x45x7TC and 32x48x8TC Not sure which one you need. I'm thinking the 48mm was the left side but have slept since last time I put one in.
                          Next installation, put some rtv or something around the outside, I personally would ditch the speedy sleeve, but if you use it, I'd make sure it was coated with something between it and the crank as well. As Brant said.. if the surface of that sleeve isn't polished, it could be just grinding on the seal lips and ruining them.
                          Lastly... grab ahold of your crank and try to wiggle it front to back, up and down. It will likely have a slight bit of in/out, movement from wear on the saddle bearing, but should be solid otherwise. If you detect some movement, it means very worn crank bearings, the crank is wobbling while running, and more seals will be a waste of time and money. When it wobbles enough, the rotor wipes out your stator on your alternator on the right side and smears your pickup coils away on the left. Fairly tight clearances on both.
                            I've replaced it 5 times now. The engine can't run with the ignition pickups removed. Can I do this using the starter motor?
                            Can I just polish the sleeve before I install it? Is there a way to make sure it's installed correctly?
                            They come with a cup that they set in for installation. use approx. same diamater wuuden/plastic mallot on the CUP to drive seal in. If you haven't been using the cup they set in, THAT is why they're leaking. ANY mior distortion(cocked to one side a bit on initial starting instalation or not using the cup provided to keep distortion from hapening.........not using the install cup WILL distort that thin metal enough. Oil has better visibilaty than you, and finds its way out.
                            • ViperRon
                              • Feb 2011
                              • 1062
                              • Woodstock, VA
                              Get the double lip seal as TRBig recommended I am sure the same design as I used and just put a smear around the seal. If its a big glob it can seal the port and if you drive the seal hard in, it will completely seal off the drain just make it barley flush. If you have the problem I did with it pushing out use the Indian head gasket shellac.
                              Rodan
                              1980 G Silverbird
                              1198 Overbore kit
                              Grizzly 660 ACCT
                              Barnett Clutch Springs
                              R1 Clutch Fiber Plates
                              122.5 Main Jets
                              ACCT Mod
                              Mac 4-2 Flare Tips
                              Antivibe Bar ends
                              Rear trunk add-on
                              • RichV
                                • May 2013
                                • 374
                                • Everywhere
                                There's no movement. I made sure of that when I resembled the crankcase. I just didn't look at the seal race very well before doing it. It has pits in it that will damage a seal faster than the speedee sleeve. So I'm going to try and polish the new one first.
                                I have two seals on hand I can try first. If the previous sleeve caused the leak than a new polished one should solve it (I hope). Meanwhile, I'll order a couple of seals from this source.
                                Also have:
