Exhaust/rear brake pedal
  • mack
    • 2411
    • Ontario, Canada
    Ok so I put the exhaust on the E this morning only to find the rear brake pedal contacts the exhaust about half way to the pivot point. Checked the books and I have everything where it's supposed to be but it still makes contact. The return spring tips to the outside and pulls the actater sleeve inward.
    The end result is this:
    So what is the secret handshake for the E rear brake system? I've considered several option like reversing the exhaust mounting gromets, but in my experience so far, if it doesn't fit easily, your doing it wrong. What am I missing?
    The exhaust is pinned in exactly like it's supposed to be so I know it's not out of line, front to back. This stupid spring thing seems mickey mouse to me. I have it tucked under the foot rest bracket like it's supposed to be. To change it to one of the recesses inside the bracket compounds the angle and pulls the pivot point in farther.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    Mack, IIRC the hook on the spring should be on the forward arm of the pedal pivot, not the rear like you have it. You're right, if it's 'correct' it goes right together but it's not obvious from looking at the parts. Also make sure you have the right spring; the standard/Special parts aren't the same but again, it's not all that obvious.
    • mack
      • 2411
      • Ontario, Canada
      Steve
      I tried to reverse it but it will not work in that config. What I did is as per the books for an f. The E manual doesn't really show it. I've flipped the spring backwards, forwards, reversed it etc. But I always have to return to the sane proble,. It's really at the first inside coil that starts tipping the spring to the outside drawing the sleeve to the inside. Anyone got a picture of what works?
      mack
      HERMES
      original owner
      81 XS 1100 LH MNS
      SPICA
      78 XS 11E
      IOTA
      613-398-6186
      • SFerinTEXAS
        • Jun 2006
        • 877
        My E spring is hooked just like yours but clearly the pedal shaft is not protruding enough for the peddle pinch bolt to go thru.
        79SF
        XJ11
        78E
        • CaptonZap
          • Jun 2010
          • 1748
          • Denver
          The pedal should fit over the splined pivot shaft, and the pinch bolt should go in the groove on the pivot shaft. That will keep the spring from driving the shaft in. It looks like the same setup on my G.
          CZ
          • mack
            • 2411
            • Ontario, Canada
            Finally
            Well I finally got it working close to perfect. Still contacts the exhaust but only at the deepest part of the pedal down stroke. Once I get all the air out, it shouldn't need to plunge that far. Had to recurve the spring and put the lever on before installing the foot pedal bracket then install it as a one piece unit, which was quite a feet trying to fit the spring under and around the swing arm bearing casting. Good thing I always put the rear motor mount bolt in from the left side. Anyway thanx for the encouragement!
            mack
            HERMES
            original owner
            81 XS 1100 LH MNS
            SPICA
            78 XS 11E
            IOTA
            613-398-6186
            • BowlingSS
              • Apr 2015
              • 398
              • Lawrenceville, GA.
              I am glad it works now.
              Bill
              Jardine Spaghetti with Harley Mufflers
              • dbeardslee
                • 4385
                • Maineville, OH
                Sounds like you got it, but I took a couple pics on my '79F just for grins.
                This is shooting from the bottom, looking straight up. The top of the pic is to the rear...
                And this is shooting across the bottom from the left side.
