Where to buy Jets online?
Be certain you get the correct ones when you order and always get original Mikuni.Greg
The list changes. -
Stock is 42.5, I run 45's with with my aftermarket exhaust. The stock mains are 137.5 but with my exhaust I run 142.5.
I'm running a Mac 4 into 2 with turnouts. Very free flowing and lean out the engine, especially at top end in 5th gear.Greg
The list changes.Comment
BTW, don't trust the application charts on jetsrus. It's wrong. Measure the physical dimensions of your jets and order accordingly.
If you have problems PM me and I can help. BTDT.Greg
Mains......http://www.jetsrus.com/a_jets_by_car...arge_round.htm
Pilots......http://www.jetsrus.com/a_jets_by_car...0-96_pilot.htm
Double check me before you order. I've made mistakes before.Greg
I'd suggest 140 on the mains at the most, and 42.5/45 on the pilots.1979 XS1100F
2H9 Mod, Truck-Lite LED Headlight, TECHNA-FIT S/S Brake Lines, Rear Air Shocks, TKAT Fork Brace, Dyna DC-I Coils, TC Fuse Block, Barnett HD Clutch Springs, Superbike Handlebars, V-Star 650 ACCT, NGK Irridium Plugs, OEM Exhaust. CNC-Cut 2nd Gear Dogs; Ported/Milled Head; Modded Airbox: 8x8 Wix Panel Filter; #137.5 Main Jet, Viper Yellow Paint, Michelin Pilot Activ F/R, Interstate AGM Battery, 14MM MC, Maier Fairing, Cree LED Fog Lights.Comment
Howdy sir- That 147.5 caught my eye. Are you running straight pipes? If not, whatever formula you used, disregard it. I've ran every type of configuration of aftermarket stuff between my XS collection, and never once jumped that high in main jet size. And, if it's running rich, going UP in size, will only make it run richer. What is your current jetting? Start with stock first. I see you have pods.
Thats the formula i saw on this thread
but whatever the bike is running i will definetly run a jet smaller. I really just needed to know where to buy the jets.79 SFComment
Pretty sure he used this chart here Ian. http://www.xs11.com/forum/showthread.php?t=382
With my exhaust I've gone up 1 size pilots and 2 sizes mains and I'm pretty much right where I need to be I think.
Finally got rid of that top end lean spark knock at WOT in 5th gear. Plugs are tan with black edges. It doesn't get better than that.Greg
I actually dont know what the bike is jetted at right now. I will find out soon. I bought bike used and its running rich for sure.
The only "formula" you should use is to start out with stock jets and and see if you need to change anything.1981 XS1100H Venturer
K&N Air Filter
ACCT
Custom Paint by Deitz
Geezer Rectifier/Regulator
Stebel Nautilus Horn
EBC Front Rotors
Limie Accent Moves On In 2015
MikeComment
True......................Greg
