Where to buy Jets online?
  • adelii
    • Jun 2015
    • 94
    • Tuscon, AZ.
    Do you guys know where i can buy different sized jets online? I have a 79 special and will be cleaning the carbs soon and wanted to dial it in. Its running rich. Cant seem to find individual jets for sale online anywhere for xs 1100 carbs.
    79 SF
    • 9981
    Be certain you get the correct ones when you order and always get original Mikuni.
      • 8062
      jetsrus.com
      • adelii
        • Jun 2015
        • 94
        • Tuscon, AZ.
        Thank you! that was fast.
        what size pilot does a 79 special have? says online there is two different sizes.
        79 SF
          • 9981
          Stock is 42.5, I run 45's with with my aftermarket exhaust. The stock mains are 137.5 but with my exhaust I run 142.5.
          I'm running a Mac 4 into 2 with turnouts. Very free flowing and lean out the engine, especially at top end in 5th gear.
            • 9981
            BTW, don't trust the application charts on jetsrus. It's wrong. Measure the physical dimensions of your jets and order accordingly.
            If you have problems PM me and I can help. BTDT.
            • adelii
              • Jun 2015
              • 94
              • Tuscon, AZ.
              Im sorry i meant size of actual jets. i guess there is different size threads.
              im going to run 45 pilot and 147.5 main
              got it off one of the threads with a formula
              im running pods and a spaghetti jardine exhaust
              79 SF
              • adelii
                • Jun 2015
                • 94
                • Tuscon, AZ.
                ok perfect. i thought it was wrong. ill pm you when im ready to order.
                79 SF
                  • 9981
                  Mains......http://www.jetsrus.com/a_jets_by_car...arge_round.htm
                  Pilots......http://www.jetsrus.com/a_jets_by_car...0-96_pilot.htm
                  Double check me before you order. I've made mistakes before.
                    • 3954
                    Howdy sir- That 147.5 caught my eye. Are you running straight pipes? If not, whatever formula you used, disregard it. I've ran every type of configuration of aftermarket stuff between my XS collection, and never once jumped that high in main jet size. And, if it's running rich, going UP in size, will only make it run richer. What is your current jetting? Start with stock first. I see you have pods.
                    I'd suggest 140 on the mains at the most, and 42.5/45 on the pilots.
                    • adelii
                      • Jun 2015
                      • 94
                      • Tuscon, AZ.
                      I actually dont know what the bike is jetted at right now. I will find out soon. I bought bike used and its running rich for sure.
                      Thats the formula i saw on this thread
                      but whatever the bike is running i will definetly run a jet smaller. I really just needed to know where to buy the jets.
                      79 SF
                        • 9981
                        Pretty sure he used this chart here Ian. http://www.xs11.com/forum/showthread.php?t=382
                        With my exhaust I've gone up 1 size pilots and 2 sizes mains and I'm pretty much right where I need to be I think.
                        Finally got rid of that top end lean spark knock at WOT in 5th gear. Plugs are tan with black edges. It doesn't get better than that.
                        • adelii
                          • Jun 2015
                          • 94
                          • Tuscon, AZ.
                          Ive noticed a weird stumble after about 6k rpm. Sometimes it does it and sometimes it doesnt. If the bike has been ridden more then 20 minutes it never does it. I guess the bike has to be really really warm to run smooth.
                          79 SF
                          • MPittma100
                            • Aug 2011
                            • 2359
                            No need to buy jets until you know what you currently have installed. Your "rich" condition could be caused by the pods or incorrect float height setting.
                            The only "formula" you should use is to start out with stock jets and and see if you need to change anything.
                            1981 XS1100H Venturer
                            K&N Air Filter
                            ACCT
                            Custom Paint by Deitz
                            Geezer Rectifier/Regulator
                            Stebel Nautilus Horn
                            EBC Front Rotors
                            Limie Accent Moves On In 2015
                            Mike
                              • 9981
                              True......................
