starter button issues
  • BowlingSS
    • Apr 2015
    • 398
    • Lawrenceville, GA.
    There are two brands that have equal ability to remove rust to consider. Available at Amazon and most auto parts stores.
    http://www.amazon.com/Workshop-Hero-...s=rust+remover
    http://www.amazon.com/Evapo-Rust-ER0...s=rust+remover
    Thanks for the links. I am sure my bike will need some. Will it work on chrome that has rust?
    Bill
    Jardine Spaghetti with Harley Mufflers
      Yep, it'll clean the rusty metal under the chrome, then it will eventually rust again but it will stay clean for a while unless you like to ride on the beach at Daytona.
      Evapo-Rust is at Harbor Freight (two isles over from the cheap Chinese torque wrenches ), Lowe's, True Value, AutoZone, Advance Auto, O'Reilly's, Pep Boys, think of another place and they probably have it too.
      The 'Metal-Rescue' version is at Home Depot.
        • 8077
        Metal Rescue is in most Home Depot stores. They have it here in Dahlonega, so they must have it in Lawrenceville. It's magic!
        • DAVINCI
          • Jan 2011
          • 1048
          • Cedar Mountain, NC
          OK, gotta chime in here, seems this thread has gotten a bit off topic. Ben, you said it happens HOT? Then I would look at the torque on the starter mounting bolts.
          JMHO
            • 6765
            JMHO
            yes cold theres no issue...its not the solenoid...starter mounting bolts huh?....i have had some other family matters come up so I have been distracted away from the bike..but hopefully by the weekend we'll get this sorted
            2005 Honda SilverWing 600
            2018 Honda PC-Xpress 150
            • DAVINCI
              • Jan 2011
              • 1048
              Two (3?) 10mm bolts attach it to the engine. BTW, I added an additional ground cable there, it's a design weak point.
                • 6765
                Two 10mm bolts attach it to the engine. BTW, I added an additional ground cable there, it's a design weak point.
                I have never touched the starter..you were the last person in there...so if everything was torqued alright to begin with would the bolts become loose over time?
                • MPittma100
                  • Aug 2011
                  • 2359
                  Rust
                  Bill
                  Part of the instructions include rinsing with water when you have removed the part from the chemical. Then immediately rinse with alcohol and dry. This is supposed to stop the flash rust.
                  There is another chemical (Dry Coat) that is recommended to use after the rust remover to prevent rust from coming back.
                  http://www.amazon.com/Workshop-Hero-...3QGHJX58VDWJA1
                  1981 XS1100H Venturer
                  K&N Air Filter
                  ACCT
                  Custom Paint by Deitz
                  Geezer Rectifier/Regulator
                  Stebel Nautilus Horn
                  EBC Front Rotors
                  Limie Accent Moves On In 2015
                  Mike
                  • BowlingSS
                    • Apr 2015
                    • 398
                    Thanks. I just ordered some of each.
                    Bill
                      More ideas for hot start problems:
                      Worn or dirty brushes
                      High mica and/or a worn commutator.
                      The starter bearings are worn and the armature is dragging/binding on the stator when it's hot.
                      • mlew
                        • Jun 2005
                        • 226
                        • Apex , NC
                        We got it fixed this evening. A combination of dirty starter button and starter relay contacts. We had to take the relay apart and clean/polish the contacts, same for the starter button. Works every time now. We spent more time shooting the breeze in the shop, it was a good evening.
                        Slow down and enjoy life. If you are in that much of a hurry, you should have left eariler.
                        Current rides:
                        80 XS1100SG
                        82 JX1100
                        83 Venture Royale
                        86 V-Max
                          • 6765
                          yes well almost as much time yakkin'...rode her the 35 miles back home and she was hummin' all the way...the reroute of the clutch cable and lubing it really improved the clutch feel...Thers no finer feelin than when your bike is running right and you're crusing down the road cooling off in the late evening air....ommmmm
                          Thankyou Mark...
