Fuel Line Clamps
  • BowlingSS
    • Apr 2015
    • 398
    • Lawrenceville, GA.
    Fuel Line Clamps
    I have new Tygon Fuel Line 1/4" ID X 3/8" OD - 10' roll clear yellow coming. What clamps if any does everyone use?
    I saw these on EBay.
    http://www.ebay.com/itm/1-4-fuel-lin...3D251783539833
    Bill
    Jardine Spaghetti with Harley Mufflers
  • BowlingSS
    • Apr 2015
    • 398
    These look cool.
    http://www.amazon.com/AAS-Fuel-Injec...el+line+clamps
    Bill
      Those will work, but with our fuel system, these will suffice.
      Get them at Parts-n-More or Mike's XS among many other places.
        • 3193
        Originally posted by BowlingSS
        No No and No to these! Tried them and they will not work well for you!
          • 3193
          Bill
          These are the type I use. I get them at my honda dealer and that is also where I find the stock replacement fuel lines which lasts many years. Our Yammy dealer has recently been taken over by someone new and I hope they stock better stuff than the old owner.
          • Diskman01
            • Mar 2011
            • 263
            • Sioux Falls, SD
            I use black plastic zip ties.
            1) Fire up Internet Explorer
            2) http://www.yahoo.com
            3) type "www.mapquest.com" into the Yahoo search page.
            4) go about day as VP managing multi-million dollar financial contracts.
              +1 on the use of the OEM fuel line. Replaced mine 10yrs. ago, and still flexible with no cracking.
              • Prothec
                • Jul 2007
                • 587
                • Fort Myers, FL
                I have those fuel lines and don't use any clamps on mine. I've had them on for a couple of years without issue. For peace of mind, I doubt you need anything more than the simple spring clamps that Marty suggested.
                Website/Blog
                  Prothec,
                  Which line do you have? OEM? My OEM line came with those spring clamps.
                  • Prothec
                    • Jul 2007
                    • 587
                    • Fort Myers, FL
                    Sorry for the confusion, I have the 1/4" e-bay Tygon lines without clamps. I just pulled my carbs last week. The ends attached to the tank came off with a bit of tugging, but nothing as difficult as bulk rubber lines from the auto store.
                    I haven't had any leaking issues and replace the fuel filters once or twice a year as they pick up bits of rust from my tank. I removed the stand filters on the petcocks to let loose rust work its way out over time.
                    I might use spring clamps when I put the carbs back in the bike this time around.
                    I had to use an easy out on a stripped out and stuck mixture screw. Time to hit up MikesXS for a new set...
                    Website/Blog
                    • Jeff Pattee
                      • Sep 2010
                      • 21
                      • Eugene, Oregon
                      Clamps
                      I have used those, and they work just fine.....a cheap alternative is a small zip tie.
                      "Pop.pa Pipes"
                      Tends to overthink even the smallest little glitches
                      1978 XS1100
                      '79 Special Tank
                      210 air pilots, 137.5 Mains
                      4 into 2 Jardines
                      1st over, standard bore
                      1978 Intake cam
                      Later style exhaust cam
                      • Jeff Pattee
                        • Sep 2010
                        • 21
                        • Eugene, Oregon
                        Mixture screw
                        VERY IMPORTANT !!! Since u had to use an easy-out, that tells me that the point of the screw may be stuck and broke off in the hole. Make sure that the hole in the casing is clear......Sometimes u can run your finger in the carb and feel the point sticking thru.
                        "Pop.pa Pipes"
                        1978 XS1100
                        '79 Special Tank
                        4 into 2 Jardines
                        1978 Intake cam
                          Prothec,
                          Hi Marty,
                          If it's of any help, my lower portion of fuel line is OEM from tees to filters, with the OEM clamps at the tees only. From the little barrel type filters, which happen to be ones used on Victory/Bomadier(spelling sucks) to my petcocks is a blue see-thru aftermarket fuel line from the same local Yammy/Victory dealer. No clamps, and they DO push off the barb petcock tees with difficulty(as you well know from all my carb 'fiddling', and ump-teen times of removal). ALL those fuel lines have now been on bike for over 7yrs. and are still flexible and do NOT kink....ever! If your interested in who the manufacturer of the blue see-thru line is, I'd be glad to run by there first of week and check. They just pull whatever you need in length out of the packaged coil and cut it off. They told me at that time they went to using it as a replacement as it is pretty much impervious to the effects of the alcohol fuel. The lower portion of the black OEM fuel line seems just as impervious to the effects of the fuel too, so guess it's buyers choice.
                          • DeanR
                            • Jan 2005
                            • 1499
                            • Finger Lakes NY
                            When I was recently reinstalling my carbs, I too got blue fuel line from my dealer, cut from a packaged coil.
                            Seems like good stuff. Of course can't comment on longevity. They said they have good luck with it, especially on snowmobiles.
                            80 SG
                            81 SH in parts
                            99 ST1100
                            91 ST1100
                              Originally posted by Prothec
                              [...] I removed the stand filters on the petcocks to let loose rust work its way out over time.
                              Prothec,
                              Just so that you're aware: when you removed the filters you also removed the On and Reserve/Prime capability from over 600 lbs. of motorcycle.
                              The filters have two "levels" built into them. The first level is above the bottom of the tank and it's used for the normal On position. The second, lower level is closer to the bottom of the tank and it's used for the Reserve and Prime positions.
                              With the filters removed, the fuel is drawn from the very bottom of the tank along with any water, sediment and rust. When the bike runs out of fuel there won't be any left for Reserve because the tank's empty.
                              Be careful!
