Hey Scott,
Thanks, I've copied your post to the Final Drive Mod tech tip, and SOMEDAY I'll fix the photos in the Forums version of the tip!
Thanks for providing the "HOW TO" and photos.
After seeing it, I "was" thinking that perhaps one might NOT need to sacrifice another U-joint Yoke?? I realize NOW from viewing your photos that when the OEM shaft and yoke are assembled, that it sticks out THRU the inner edge/end of the yoke towards the U-joint...that way the Keeper Expansion ring can open to help secure the shaft in place. I was thinking that perhaps one could cut off a lot of the the OEM yoke piece, then put a simple plain PIPE/Tube section in between the cutoff part of the yoke and the NOW splined end piece, both getting welded onto the OEM yoke. The expansion spacer would have a wide enough ID to NOT engage the splines of the driveshaft, and would still put a major amount of the YOKE spline section very close to the full engagement point on the driveshaft splines. And with the wider Expansion section/area in between, the expansion RING can still have room to expand to help secure the driveshaft in place.
Anythoughts on this approach??
