Maybe whilst running but not when the engine is off.
I'm seeing dried up O-rings on the float valves and your old float needle rubber tips are hard so replacement of most rubber parts and good cleaning/polishing of the correct areas along with the new float needles you provided will most likely cure the leakage but I will bench test to confirm.
The diaphragms look good.
I believe we should rebuild the octy and replace the Butterfly shaft seals also.
