2nd Gear Fix. Any Words of Wisdom? :)
I personally am not a great fan of the Dremel fix. One is definitely removing the hardened surface of the gear and there have been cases of the fix failing after all that strip down work. I would personally look for a good used transmission or even buy new gears. I can't imagine anything worse than doing the 'fix' and find it doesn't work or fails soon..
Re the washer swap. I've tried this on three engines out of the frame and never once succeeded in getting the shaft back in after the swap. I was using old scrap engines to practice and once spent two hours of trying, without success. That's with the engines on the ground, upside down and as easy to work on as could be. I've been told that I was somehow doing it wrong but I still don't see how. It would be even worse with the bike on its end, or upside down, or crawling underneath it!XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.Comment
I tend to agree with you on this one James...the 2nd gear washer swap was/is appropriate when replacing the gearsets rather than dremmelling them...when I had my 2nd gear issues with the Maxim...i elected to but new gearsets and swap them out rather than dremel the old sets...at that time I spent over $500 USD for the gearsets...I have heard since then that Yamaha has stopped making them ,but I have not ascertained that this is so...
What I am certain of ...is that those gears wll never break again...or at least as long as I was alive....
2018 Honda PC-Xpress 150Comment
It might be one of the various reasons I have two extra XS engines sitting in storage. I'd much rather swap gears than dremel. Then again, with my bike already having the fix done, I doubt I'll ever have to worry about it again.1979 XS1100F
2H9 Mod, Truck-Lite LED Headlight, TECHNA-FIT S/S Brake Lines, Rear Air Shocks, TKAT Fork Brace, Dyna DC-I Coils, TC Fuse Block, Barnett HD Clutch Springs, Superbike Handlebars, V-Star 650 ACCT, NGK Irridium Plugs, OEM Exhaust. CNC-Cut 2nd Gear Dogs; Ported/Milled Head; Modded Airbox: 8x8 Wix Panel Filter; #137.5 Main Jet, Viper Yellow Paint, Michelin Pilot Activ F/R, Interstate AGM Battery, 14MM MC, Maier Fairing, Cree LED Fog Lights.Comment
The nay sayers are always those who have not or cannot. I have 4 11s in the garage as I type this that I know have been repaired this way. All are or were working before they were parked for other reasons.
Hmmm.......maybe I was just fortunate that I dropped that shaft assembly out of mine on centerstand, and re-installed. Centerstand up on short 6"x6" block and rocked back blocking under and in front of front wheel allowed fairly easy access to underside.I personally am not a great fan of the Dremel fix. One is definitely removing the hardened surface of the gear and there have been cases of the fix failing after all that strip down work. I would personally look for a good used transmission or even buy new gears. I can't imagine anything worse than doing the 'fix' and find it doesn't work or fails soon..
Stripping down the Venturer so as to flip it was not happening
81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
Here is your answer and procedure to get shaft back in..... ez pzI personally am not a great fan of the Dremel fix. One is definitely removing the hardened surface of the gear and there have been cases of the fix failing after all that strip down work. I would personally look for a good used transmission or even buy new gears. I can't imagine anything worse than doing the 'fix' and find it doesn't work or fails soon..
1979 F worst one i could find
to convert into a bobber/ streetfighter!
_________________________________
We can't all get along!Comment
