2nd Gear Fix. Any Words of Wisdom? :)
  • Rasputin
    • 3193
    • Lacombe, Alberta, Canada
    Originally posted by BA80
    I put mine in neutral all the time when I'm sitting at lights here.
    Here it is a requirement, when testing for your license to put the bike in neutral when at a light. The point being that if the clutch failed or you accidentally released it, you would not be shot into traffic.
    2-79 XS1100 SF
    2-78 XS1100 E Best bike Ever
    • James England
      • 3039
      • North of England
      I personally am not a great fan of the Dremel fix. One is definitely removing the hardened surface of the gear and there have been cases of the fix failing after all that strip down work. I would personally look for a good used transmission or even buy new gears. I can't imagine anything worse than doing the 'fix' and find it doesn't work or fails soon..
      Re the washer swap. I've tried this on three engines out of the frame and never once succeeded in getting the shaft back in after the swap. I was using old scrap engines to practice and once spent two hours of trying, without success. That's with the engines on the ground, upside down and as easy to work on as could be. I've been told that I was somehow doing it wrong but I still don't see how. It would be even worse with the bike on its end, or upside down, or crawling underneath it!
        • 6765
        I tend to agree with you on this one James...the 2nd gear washer swap was/is appropriate when replacing the gearsets rather than dremmelling them...when I had my 2nd gear issues with the Maxim...i elected to but new gearsets and swap them out rather than dremel the old sets...at that time I spent over $500 USD for the gearsets...I have heard since then that Yamaha has stopped making them ,but I have not ascertained that this is so... What I am certain of ...is that those gears wll never break again...or at least as long as I was alive....
        2005 Honda SilverWing 600
        2018 Honda PC-Xpress 150
          • 4013
          It might be one of the various reasons I have two extra XS engines sitting in storage. I'd much rather swap gears than dremel. Then again, with my bike already having the fix done, I doubt I'll ever have to worry about it again.
            • 9981
            The nay sayers are always those who have not or cannot. I have 4 11s in the garage as I type this that I know have been repaired this way. All are or were working before they were parked for other reasons.
              • 6765
              #36
              I'm not a naysayer...but for MY peace of mind I replaced them...YMMV
                Hmmm.......maybe I was just fortunate that I dropped that shaft assembly out of mine on centerstand, and re-installed. Centerstand up on short 6"x6" block and rocked back blocking under and in front of front wheel allowed fairly easy access to underside.
                Stripping down the Venturer so as to flip it was not happening.
                • Fearthepack
                  • May 2012
                  • 255
                  • Orlando, Fla.
                  #38
                  Here is your answer and procedure to get shaft back in..... ez pz
                  1979 F worst one i could find
                  to convert into a bobber/ streetfighter!
                  _________________________________
                  We can't all get along!
