I could install new (longer) exhaust studs and use the new elongated nuts I bought, or use SHCS. Opinions?
Studs or Bolts?
Studs or Bolts?
2H9 Mod, Truck-Lite LED Headlight, TECHNA-FIT S/S Brake Lines, Rear Air Shocks, TKAT Fork Brace, Dyna DC-I Coils, TC Fuse Block, Barnett HD Clutch Springs, Superbike Handlebars, V-Star 650 ACCT, NGK Irridium Plugs, OEM Exhaust. CNC-Cut 2nd Gear Dogs; Ported/Milled Head; Modded Airbox: 8x8 Wix Panel Filter; #137.5 Main Jet, Viper Yellow Paint, Michelin Pilot Activ F/R, Interstate AGM Battery, 14MM MC, Maier Fairing, Cree LED Fog Lights.Tags: None -
Okey dokey. I'll head to Auto Zone in the morning and see what my options are. If not, Ace sells studs. Just want something longer, so I never have to fight with it again.1979 XS1100F
2H9 Mod, Truck-Lite LED Headlight, TECHNA-FIT S/S Brake Lines, Rear Air Shocks, TKAT Fork Brace, Dyna DC-I Coils, TC Fuse Block, Barnett HD Clutch Springs, Superbike Handlebars, V-Star 650 ACCT, NGK Irridium Plugs, OEM Exhaust. CNC-Cut 2nd Gear Dogs; Ported/Milled Head; Modded Airbox: 8x8 Wix Panel Filter; #137.5 Main Jet, Viper Yellow Paint, Michelin Pilot Activ F/R, Interstate AGM Battery, 14MM MC, Maier Fairing, Cree LED Fog Lights.Comment
Hardware stores sell the studs and my experience is they are better the ones from auto stores seem to rust and seize and they only had kits when I was there. I suggest bestbuy or ACE hardware or the dealer.To fix the problem one should not make more assumptions than the minimum needed.
Rodan
1980 G Silverbird
1198 Overbore kit
Grizzly 660 ACCT
Barnett Clutch Springs
R1 Clutch Fiber Plates
122.5 Main Jets
ACCT Mod
Mac 4-2 Flare Tips
Antivibe Bar ends
Rear trunk add-on
http://s1184.photobucket.com/albums/z329/viperron1/Comment
The only issue I see is the stress it puts on the cylinder head threads everytime the exhaust comes off (for me, it comes off every year).1979 XS1100F
With a stud, you can get the maximum amount of thread engagement into the head; the stud is threaded in until it bottoms. You can't do that with a bolt, and the risk of pulling the threads out of the aluminum head are much higher.Fast, Cheap, Reliable... Pick any two
I have one xs11 standard with Jardine 4-1's and there is clearance only for a bolt rather than a stud and nut at one location. I didn't really much like it, but you are only mashing the crush washers and not bearing down with much torque.Skids (Sid Hansen)
I recently changed out my exhaust on my 79 Special from an old rusty 4 into 1 header to some nice new Mac 4 into 2 flare tip chrome pipes. Whoever had installed the header had used bolts and many washers to mount them to the head. They had been torqued so tight that the flanges were bending in. When I took them out I found that only about half an inch of thread was in the head. Lucky they hadn't stripped out. For the new exhaust I went to my local auto parts store and got new studs, nuts and lock washers. Like Crazy Steve says, much better. I screwed the studs into the head right to the bottom before mounting the exhaust.
Graham in Surrey, B.C., Canada
1979 XS1100 Special.
Mac 4 into 2 chrome exhaust.
Dyna high performance coils.
Drilled air box.
K&N air filter.
Pics https://www.dropbox.com/sh/4tpyuurw3...XjCLWeTVa?dl=0Comment
Yes, I have a helicoil in my number 4 cylinder.1979 XS1100F
