Horn
  • mack
    • 2411
    • Ontario, Canada
    Horn
    whats a good horn that will fit an XS and sound like the Titanic coming into to dock?
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    • 2083
    Fiamm horns are pretty loud.
      • 3918
      +1 They are marketed under different names, Wolo Bad Boy is another. Requires a relay install due to the demand of draw. Horn install will have to be a custom mount.
      • webbcraft2150
        • Sep 2002
        • 1605
        • AUSTIN.TX
        Fiamms or the look a likes at auto stores. Very loud. Will require a relay and custom mounting. I was able to use the stock mounting point with some homemade brackets. Mounted relay in same area. Stock horn wiring powers relay. Ran power to relay from battery with fuse. Turns a "please don't run me over" beep to a "move the freak over" wail.
          Hey Mack,
          The Stebel Nautilus series are the original brand name type.
          The Wolo brand has 2 variations, the 419 and 619.
          All of these are compressors mounted directly to the horns....not hoses or such needed.
          http://www.amazon.com/Stebel-Nautilu.../dp/B00CMX20H4
          http://www.harborfreight.com/bad-boy...orn-94117.html
          http://www.amazon.com/gp/product/B00...d_i=B00CMX20H4
          Here's a FIAMM single electric horn type, but you'll need to wire in a relay just like the above ones to handle the current draw it will require.
          http://www.amazon.com/FIAMM-72112-Fr...6K1EZHSQEAKXQY
          These are the ones I put on mine, they are fairly loud, definitely louder than the OEM type, but probably not as loud as the compressor types above.
          http://www.amazon.com/FIAMM-74100-El...iamm+el+grande
          HTH.
          • mack
            • 2411
            • Ontario, Canada
            Thanx
            I'll scope them out and let you know what I chose.
            mack
            HERMES
            original owner
            81 XS 1100 LH MNS
            SPICA
            78 XS 11E
            IOTA
            613-398-6186
            • DeanR
              • Jan 2005
              • 1493
              • Finger Lakes NY
              Just had the Stebel go caput after about 5 years. Only the compressor noise now, no toot.
              I think I'll try the Fiamms next.
              80 SG
              81 SH in parts
              99 ST1100
              91 ST1100
              • webbcraft2150
                • Sep 2002
                • 1605
                • AUSTIN.TX
                Check out this rig. Ebay has em. Sea Ray Boat horn #1780938. OEM on a Sea Ray Boat. Its electronic, not a diaphragm style. Draws very little juice, like milliamps. I was replacing horns on my boat almost every year till I put one of these in. Still going strong after 9 years. Totally waterproof. Noise it puts out is very similar to the electronic horn on a cop car, very very loud and unique sound that should get a cagers attention pretty quick. I will be mounting two of these in my Windjammer when my current set of Fiamms take a dump. I am sure with some creativity, they could be mounted on a naked bike.
                • TomB
                  • Aug 2006
                  • 967
                  • Cumbria, UK
                  Go on, you know you want to....
                  Tom
                  • b.walker5
                    • Feb 2009
                    • 1745
                    • Invercargill, New Zealand
                    We must have better drivers down this way... About the only time i know my horns work is during its annual safety inspection, or when i occasionally mistake it for the start button... Almost never use 'em. Dont need too.
                    • mack
                      • 2411
                      • Ontario, Canada
                      LoL
                      Can't say I've ever used mine on the SF or LH either, but it's that one time you really need it, and all you get is a squeak! That could make the difference in one of the frequent, parking lot or intersection accidents we all hear about.
                      mack
                      HERMES
                      original owner
                      81 XS 1100 LH MNS
                      SPICA
                      78 XS 11E
                      IOTA
                      613-398-6186
                        • 6762
                        Stebel's quality has gone downhill over the years so while they are loud they dont seem to last as long anymore...Fiamms I have heard are a good choice... you should get 2 one in Low tone and one in high tone....Regardless of which horns you buy, I reccommend you buy a specific wiring harness with a relay. Dont use your existing wires as the current drawn from these horns will exceed the orig. wires capacity and will burn up.... Having said that I'm not sure who makes a horn /relay harness ...used to be a guy in Jaapan...will have to see if i can find that...
                          Nothing really to it. Buy yourself some 12awg stranded wire, get an appropriate sized single pole single throw relay an hook it up. Run the 12 awg wire straight to the battery and trigger the relay with the original horn wire.
                          No sense paying $30 plus shipping for something you could do (probably better) for less than $10.
                            Hi Mack,
                            Canadian Tire carries the Fiamm for about $30 a pair.
                            I have them on my XJ650. I call them my "wake the trucker horns"
                            While I never needed to wake a trucker it is good to have.
                              • 7766
                              You forgot ONE IMPORTANT THING!! Put a 20A Fuse near the battery! without a fuse, you can fry a LOT of the bike and wires. If you have a TC fuse block, wire the relay through a 20A fuse in it.
