Street fighter/ Bobber build 2.0
  • Fearthepack
    • May 2012
    • 255
    • Orlando, Fla.
    Build 1.0 halted at this stage: Running but discovered 2nd gear fix was immediately needed. Halted because of many other projects the main one needed to build a work shop to work in. Upon tear down discovered melted wire connection any ideas of its cause?
    <a href="http://s1303.photobucket.com/user/Fearthepack/media/037_zpszvpgtsba.jpg.html" target="_blank"><img src="http://i1303.photobucket.com/albums/ag151/Fearthepack/037_zpszvpgtsba.jpg" border="0" alt=" photo 037_zpszvpgtsba.jpg"/></a>
    <a href="http://s1303.photobucket.com/user/Fearthepack/media/Palackaxs1100ltz400%20115_zpsyfhad48q.jpg.html" target="_blank"><img src="http://i1303.photobucket.com/albums/ag151/Fearthepack/Palackaxs1100ltz400%20115_zpsyfhad48q.jpg" border="0" alt=" photo Palackaxs1100ltz400 115_zpsyfhad48q.jpg"/></a>
    <a href="http://s1303.photobucket.com/user/Fearthepack/media/Palackaxs1100ltz400%20106_zpsryozzi54.jpg.html" target="_blank"><img src="http://i1303.photobucket.com/albums/ag151/Fearthepack/Palackaxs1100ltz400%20106_zpsryozzi54.jpg" border="0" alt=" photo Palackaxs1100ltz400 106_zpsryozzi54.jpg"/></a>
    <a href="http://s1303.photobucket.com/user/Fearthepack/media/Palackaxs1100ltz400%20105_zpsp0yo8jx9.jpg.html" target="_blank"><img src="http://i1303.photobucket.com/albums/ag151/Fearthepack/Palackaxs1100ltz400%20105_zpsp0yo8jx9.jpg" border="0" alt=" photo Palackaxs1100ltz400 105_zpsp0yo8jx9.jpg"/></a>
    1979 F worst one i could find
    to convert into a bobber/ streetfighter!
    _________________________________
    We can't all get along!
  • Fearthepack
    • May 2012
    • 255
    • Orlando, Fla.
    Ok I will try photos another way. Crap
    • phatts27
      • Aug 2012
      • 189
      • Clementon, New Jersey
      Hey fearthepack,
      I see your using photobucket. To post pics here:
      Select the picture on photobucket.
      Click the chain link icon
      Copy the bottom code labeled "IMG"
      Paste the same code on to you forum entry. (No extra brackets or code needed)
      Hit preview before submitting the post to make sure all is well.
      Hope this helps,
      Ed
      81 xs1100 SH
      81 xs1100 SH (parts)
      80 suzuki gs550et
      07 suzuki S40
      • Fearthepack
        • May 2012
        • 255
        • Orlando, Fla.
        Pics again:
        • Fearthepack
          • May 2012
          • 255
          • Orlando, Fla.
          Thanks pfatts27
          • TomB
            • Aug 2006
            • 967
            • Cumbria, UK
            The burnt wire and connector block is the feeds from the generator to the Rectifier/regulator, the contacts corrode and over heat causing the burning, a common sign of this happening is your tacho needle flickering as it uses one of the wires for its signal.
            Tom
            Tom
              • 1566
              See if that works??
              btw: very nice, I like it.
              • Fearthepack
                • May 2012
                • 255
                • Orlando, Fla.
                Cleaning connections is the cure. Any chance of a wire fire. Do I need to replace the burnt connection?
                  • 7712
                  try here: http://www.oregonmotorcycleparts.com/connectors.html for new connectors and crimpers if you don't have the correct type. This is what I have used with no problems, and Tony, aka geezer, is also a member here. I keep a selection at home, as I'm working on a '79 standard now, and will be working on a '78 after this one is done.
                  Just an aside, I like the bike, but you should look into the "loop" a lot of bobber's and cafe bikes use. Helps clean up the looks of the rear frame.
                  • mrhammer2u
                    • Aug 2014
                    • 472
                    • Northern, NJ
                    What's the purpose of what you did here (circled in red). That so you can get seat low as possible? If yes, what seat you using, where you get it from? Thanks!
                    Rob - 79 SF
                    • Fearthepack
                      • May 2012
                      • 255
                      • Orlando, Fla.
                      Yes to lower seat for the Bobber effect. I did the fiberglass over waxed foil trick to make a seat pan that fits over the new seat section. Then took the pan to an upholstery shop to build me a seat. I have back issues so I wanted a thick seat for comfort it maybe a little thick will see. I will take a pic when I get home for you.
                      • Fearthepack
                        • May 2012
                        • 255
                        • Orlando, Fla.
                        Base gasket was leaking real bad so I'm going to replace so out comes engine for gaskets and 2nd gear fix.
                        • Fearthepack
                          • May 2012
                          • 255
                          • Orlando, Fla.
                          Well on the way!
                          • Fearthepack
                            • May 2012
                            • 255
                            • Orlando, Fla.
                            Upon tear down I noticed the dots on the cam did not match up with the arrows.
                            And only the exhaust cam gear had the arrow above its bolt hole in the correct orientation the intake did not.
                            • Fearthepack
                              • May 2012
                              • 255
                              • Orlando, Fla.
                              Seat pic
