What's the size of the tank holding bolt
  • 3Ddesignsxs11
    • Oct 2014
    • 30
    • San Diego, CA.
    I am missing the bolt between the seat and that tank that holds the tank down. Does anybody know the size including the length?
    Thanks in advance!
    79 XS Eleven 1100F
    01 Triumph Tiger 955i
    91 BMW 75S Custom
    • 4015
    If you have a Standard, it's the same bolt holding your horn bracket to the frame. It has a 10mm head on it, and if I were to guess, it's probs an M8x12.
      The part number says that is correct. 97013-08012-00
      • 3Ddesignsxs11
        • Oct 2014
        • 30
        • San Diego, CA.
        Yes it's a standard.
        I did find the part number, but that doesn't help. There are actually a whole list of compatible or revised parts for this bolt, but non of them say what the size is.
        Thanks again
        79 XS Eleven 1100F
        91 BMW 75S Custom
          Thanks again
          The clue is in the part number. 97013-08012-00 =M8X12
          • 3Ddesignsxs11
            • Oct 2014
            • 30
            • San Diego, CA.
            Awesome. Thanks so much!
            79 XS Eleven 1100F
            91 BMW 75S Custom
              Thanks in advance!
              Hi 3Ddesigns,
              You are probably missing the washer that goes on top to spread the load on the rubber grommet.
              Louwes or Ace will have the bolt.
                • 7844
                Hi 3Ddesigns,
                You can use a 5/16" "small" fender washer in place of the missing one. It should be about 1 1/4" in diameter. Ace has them in stainless steel, and it makes a nice look when you take the seat off.
                • 3Ddesignsxs11
                  • Oct 2014
                  • 30
                  • San Diego, CA.
                  Thanks guys. You're right I do need the washer too, and it's a good idea to keep them all stainless.
                  79 XS Eleven 1100F
                  91 BMW 75S Custom
