2nd gear issue came back
    • 8863
    Not a countershaft gear.
    • thumperjsa
      • Apr 2004
      • 546
      • Coconut Creek, Florida
      I trust Phil more than an eBay guy. He would know if that is what you needed.
      Owned by a pair of XS11's. An 80 Standard and a 79 Special.
        • 8863
        Yep Jonathan, that gear is not the one that goes bad on the countershaft, it may be a gear that is used on the main shaft, not removable without splitting the engine cases.
          • 2121
          Nope
          That's the 5th pinion gear, not the coveted 5th 'wheel' gear on the countershaft.
          • Tenorman
            • Oct 2013
            • 70
            • Butler, Penn.
            Yes...But...
            That is a 5th gear for the XS1000...5th Gear Pinion according to the parts diagram...2H7-17151-00-00.
            But it's not the gear that generally is bad...that would be 2H7-17251-00-00...the one that engages with the 2nd Gear (2H7-17221-00-00)
            But, if you need that gear, it would be a good idea to but it now....
            Just a thought....
            Tenorman
            Bikes that I have owned and enjoyed...
            1964 Allstate 250
            1970 Yamaha DT1
            1959 Mobylette
            1970 Yamaha JT1
            1995 Suzuki 80
            1978 Yamaha XS650
            1980 Yamaha XS1100LG
            2005 BMW R1150R
            • Tenorman
              • Oct 2013
              • 70
              • Butler, Penn.
              Oooops....
              You guys are soooo fast....
              By the time I checked the ebay photo and the part number, the answers were already posted....
              I'm not as fast as I used to be....
              Tenorman
              1964 Allstate 250
              1970 Yamaha DT1
              1959 Mobylette
              1970 Yamaha JT1
              1995 Suzuki 80
              1978 Yamaha XS650
              2005 BMW R1150R
              • Fearthepack
                • May 2012
                • 255
                • Orlando, Fla.
                Wouldstalk, It was pointed out to me recently that if your shift drum for 2nd/5th is worn then the dremel fix will be temporary.
                1979 F worst one i could find
                to convert into a bobber/ streetfighter!
                _________________________________
                We can't all get along!
                  It's been said here before but bears repeating.... Make sure your shifting technique is right. These transmissions need a firm, FULL stroke of the lever to shift properly. Doing it with 'finesse' can result in the gear not fully engaging and it will pop out of gear. Yes, the trans will sound 'clunky' when you do this right, but that's the nature of the beast. Do it with finesse a few too many times and you're going into the trans...
                  There's a lot of these bikes that have never had any transmission issues, and a large number that have had 'the fix' with thousands of trouble-free miles since. Fred always says 'they shift like a Russian tractor' but what he means is you have to shift them like you really mean it....
