Cheap mikuni jets
  • Donmystic1
    • Jun 2014
    • 185
    • Mystic, CT
    Jets
    Highly customized 1979 XS 1100 with carb problems, Need advice
    [/IMG]
    78E, 79F, 80G
      Originally posted by Donmystic1
      Here is my problem.
      My highly customized 79 XS 1100 is not firing on the number 3 cyl.
      The engine runs very rich and I have changed the spark plugs three times and they still coke up with soot.
      I have spark and compression. Spark plug is firing. On number 3
      Upon disassembling the carbs I find:
      The air idle adj. is turned down to 1/2 turn out ( it should be 2.5 turns out ?)
      Number 110 main jets, three pilot jets are the 2.2.2.2 style and the number 3 carbs jet is a 1.2.1.2 style and is older than the other three and plugged with debris.
      Why would some use 110 vs 137.5 mains? and what style pilot jet is the correct
      jet ( the 2.2.2.2 or the 1.2.1.2 )?
      Answered your own question, 45pilots(BS30/96...1-2-1-2) and a good carb cleanin'.
        1-2-1-2 is the correct pilot jet. As to the main jets the 110 was in the late model carbs and the 137.5 was in the early model carbs.
        • Donmystic1
          • Jun 2014
          • 185
          • Mystic, CT
          Jets
          Thanks Nate.
          I found a package of (4) 1.2.1.2 on ebay for $8.95.
          Wouldn't the 137.5 Jets be bigger than the 110's and by extension make the mixture more rich? I have an over richness problem now.
          78E, 79F, 80G
            Thanks Nate.
            78-79 carbs function differently than 80-XJ carbs, also differences of metering rods, emulsion tubes, etc.
            • Donmystic1
              • Jun 2014
              • 185
              • Mystic, CT
              Jets
              Thanks Motoman,
              I guess that is way the 110 mains are there and someone replaced three of the wrong pilot jets with 2.2.2.2's.
              I will leave the 110's in place and replace the 2.2.2.2's with 4 1.2.1.2's
              That will be after I clean and blow out all the passages.
              Thanks all.
              Don
              78E, 79F, 80G
                Thanks Motoman,
                Thanks all.
                Don
                Might want to figure out for sure what carbs you are working with and not just assume that the 110's are correct.
                • Donmystic1
                  • Jun 2014
                  • 185
                  • Mystic, CT
                  Carbs
                  Hi again Nate,
                  How do you identify a carb set?
                  Also is there a link to setting the correct float height?
                  Don
                  78E, 79F, 80G
                    • 3950
                    Don- The "Search" function is your friend, answering all of your questions addressed dozens of times.
                      Hi again Nate,
                      Don
                      Carb ID
                      We can deal with floats when we know what you have.
                        • 3950
                        Might help to start your own thread after you've done your research. This thread pertains to a place to purchase jets.
                        • thumperjsa
                          • Apr 2004
                          • 546
                          • Coconut Creek, Florida
                          Ian, thanks for the update. I am going to order a set of jets for mine and see if I can up the mileage a bit with some real ones.
                          Owned by a pair of XS11's. An 80 Standard and a 79 Special.
