Cheap mikuni jets
    • 4015
    Cheap mikuni jets
    Been researching jetting for a '78 carb, and ended-up ordering 45 Pilot Jets and 137.5 Main Jets from Amazon. Both sets priced @ $12 for 4. Quite a deal!
  • MPittma100
    • Aug 2011
    • 2359
    Jets
    Do you have a link for those jets?
    1981 XS1100H Venturer
    K&N Air Filter
    ACCT
    Custom Paint by Deitz
    Geezer Rectifier/Regulator
    Stebel Nautilus Horn
    EBC Front Rotors
    Limie Accent Moves On In 2015
    Mike
      • 4015
      http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
        It's funny that the picture of the Jets sold by miking on amazon have the R&D logo on them.
          Noticed that.......RD's are really close in metered sizing to the Genuine Mikuni, least closer than K&L's. Still a bit oversized in comparison, but will get things back up and runnin' fairly decent if cost has to be the trade-off.
            • 4015
            Cost was not necessarily a factor for me. Hopefully the pic is wrong, and they are indeed Genuine Mikuni jets.
              You will find out when you get them.
              • mack
                • 2411
                • Ontario, Canada
                Jets
                Make sure you come back and let us know if they are genuine!
                mack
                79 XS 1100 SF Special
                HERMES
                original owner
                81 XS 1100 LH MNS
                SPICA
                78 XS 11E
                IOTA
                https://youtu.be/wB5Jfbp6SUc
                https://youtu.be/RaI3WYHSuWA
                Frankford, Ont, Canada
                613-398-6186
                  Ian:
                  I'm a little worried when I see the holes on the side of the pilot jets have the 2-2-2-2 pattern. The original Mikuni seem to have the 1-2-1-2 pattern.
                  I think we agree the holes themselves aren't used in our carb design, but the 2-2-2-2 pattern may have the wrong jet opening for the stated size.
                  WMarshy had an informative post about it, but I didn't find it right away.
                  Hope you jets turn out to be what you hoped.
                    • 4015
                    Mike- Amazon or whoever is using EBC 's RD jet as the image for the jet. The description for the jet is "Mikuni", so we'll see what exactly is in-error. Hopefully the image.
                    • thumperjsa
                      • Apr 2004
                      • 547
                      • Coconut Creek, Florida
                      So Ian, did you get them yet and do you have pics? Amazon is usually good on returning items if they are incorrect.
                      Owned by a pair of XS11's. An 80 Standard and a 79 Special.
                        • 4015
                        They will arrive on Tuesday Thumper. Will def keep u guys posted.
                          • 4015
                          Update
                          For those curious, the links I provided are for GENUINE MIKUNI jets. I received both Main & Pilots today.
                          Mike- The hole pattern is indeed 1-2-1-2. Happy Jet-purchasing!
                            Yeah! ....For you and for others in the future.
                            Thanks for reporting your find.
                            • Donmystic1
                              • Jun 2014
                              • 185
                              • Mystic, CT
                              Jets?
                              Here is my problem.
                              My highly customized 79 XS 1100 is not firing on the number 3 cyl.
                              The engine runs very rich and I have changed the spark plugs three times and they still coke up with soot.
                              I have spark and compression. Spark plug is firing. On number 3
                              Upon disassembling the carbs I find:
                              The air idle adj. is turned down to 1/2 turn out ( it should be 2.5 turns out ?)
                              Number 110 main jets, three pilot jets are the 2.2.2.2 style and the number 3 carbs jet is a 1.2.1.2 style and is older than the other three and plugged with debris.
                              Why would some use 110 vs 137.5 mains? and what style pilot jet is the correct
                              jet ( the 2.2.2.2 or the 1.2.1.2 )?
                              78E, 79F, 80G
