Starter Squeal
  • Eastcoaster
    • Jan 2012
    • 513
    • oceancity NJ
    Starter Squeal
    My starter is really beginning to squeal quite loudly when the bike starts.
    So far it starts fine.
    Is there a bearing I can replace?
    Lubricate something?
    Or should I replace it all together? Is there a good source for new starters?
    My fear it is going to get worse.
    82 XJ1100J
    81 Venturer
  • phatts27
    • Aug 2012
    • 189
    • Clementon, New Jersey
    I have the starter from both of your SH's. I'm pretty sure xs1100 starters are all the same. No problem for me to give one or both back.
    81 xs1100 SH
    81 xs1100 SH (parts)
    80 suzuki gs550et
    07 suzuki S40
    • Eastcoaster
      • Jan 2012
      • 513
      • oceancity NJ
      Ed Do they even turn? They were both in the deep 6 (nautical expression). I would have thought as crusty as what we saw with the rest of the bike.
      How is the build coming?
      82 XJ1100J
      81 Venturer
      • rover
        • Jan 2004
        • 765
        • central WI (715)
        starter
        XS850 and 750 should fit also. The 850 has the same part number.
        79 F (Blueballs)
        79 SF (Redbutt)
        81 LH (organ donor)
        76 CB 750 (gone to MC heaven)
        rover has spoken
        • phatts27
          • Aug 2012
          • 189
          I never checked them to see if they work. They looked pretty good but the rest was covered in barnacles!
          Some progress made. I got the carbs looking spiffy bit I'm still waiting on those air jets to bolt everything back together.
          I'll check out those starters tomorrow.
          81 xs1100 SH
          80 suzuki gs550et
          07 suzuki S40
            If your trying to start it in 6 feet of snow and near 0 temps your lucky if it engages at all. The cold makes the starter clutch squeal pretty good.
            • phatts27
              • Aug 2012
              • 189
              Starter #1 is a no go. I'll dig up #2 and see what's what.
              81 xs1100 SH
              80 suzuki gs550et
              07 suzuki S40
                It's a pretty simple fix. Take off your starter. Remove the two long Phillips screws going down each side of the starter. Don't worry, nothing is spring loaded or going to jump out at you. Just pay attention to how it's situated though, as there's a notch you have to line up to get back together. Remove the cover that is opposite the end that goes into the engine case with the gear. (The end you see on the outside) You'll see a round nub of metal on the starter and the hole it spins in on the cap. This is the "Bearing" for that end of the spinning starter. It gets dry and sounds like a dying goose. Put a dab of grease on that nub.. not a lot.. you don't want it slinging grease around inside.. and slap it back together. Problem solved.
                  I'm with Tod,.. except why not clean and lube the planetary gears at the other end since you would already have it apart? It's really easy to remove and service the XS11 starter.
                  Bonus- can clean the commutator with fine sandpaper (600ish).
                  I had an XS750 starter that made a ZZZZZTT sound. I replaced the starter clutch, and the replacement clutch slipped. Replaced the clutch again. Still squealed. It was the lubrication inside the starter motor.
                  • mrhammer2u
                    • Aug 2014
                    • 472
                    • Northern, NJ
                    EC,
                    I had a propane heater on my scoot for about 20 min today. Fired right up with the slightest touch of the button. Could just be too cold.
                    Rob - 79 SF
                    • Eastcoaster
                      • Jan 2012
                      • 513
                      • oceancity NJ
                      The Goose is greased
                      The Goose is greased not a squawk!
                      Thanks!!!
                      82 XJ1100J
                      81 Venturer
                        • 4015
                        Any chance of getting a pic of that Lube point??? Thanks.
                          I forgot.. there's an o-ring on that cap when you take it off, so just be careful with that.
                            • 2117
                            With the howling wind in N.J., I went to my Moms house where i keep both bikes in the winter time.Both bikes fired right up.I do keep Marine StaBil in the tanks all winter long and keep a supply of fresh gas on hand.The XS just seems to take longer to catch in the cold weather.
                              • 4015
                              Thanks! Added to the to-do list.
