Automatic Cam Chain Tensioner Installation Trick
  • Orange4
    • Sep 2013
    • 398
    • Maple Ridge, B.C., Canada
    I was messing around with my ACCT and when I took it apart I noticed a second thread on the spring retaining bolt. It turns out it's a reverse thread that engages the punger and when it's fully retracted and turned anti-clockwise. You can then install it assembled, make sure the chain is tight on the sprockets and release the plunger one handed. Less chance of the chain skipping a tooth. I made a video showing how to set it. (Thumbnail was in the way of a heavy object earlier that week.)
    Living to EXcess.
    1979 XS1100F Canadian, stock exhaust. Top end rebuild in progress.
    • 2104
    discovery now I'm going to the garage to see if my extra one does that
    Thanxs for the video
      • 4015
      Holy smoley!!! How in the mother eff did your whole nail turn black??? Hard object as-in a marching band trampling on it???
      • Donmystic1
        • Jun 2014
        • 185
        • Mystic, CT
        Cam
        Thats the nail that he puts his "Coke" on
        78E, 79F, 80G
        • Orange4
          • Sep 2013
          • 398
          Yeah, and that was one really big can of coke, let me tell ya.
          Actually, I don't remember how that happened. Blocking it out, I guess. I do remember drilling a hole through the nail to relieve the pressure though. Must have been on coke.
          Living to EXcess.
          • donebysunday
            • Oct 2012
            • 1737
            • New Berlin, Wi.
            Can you tell us which model that ACCT came off of ? T.I.A. Don'e
            Oh and yes beautiful job your doing on your bike !
            76 XS650 C ROADSTER
            80 XS650 G Special II
            https://ibb.co/album/icbGgF
            80 XS 1100 SG
            81 XS 1100LH/SH DARKHORSE
            https://tinyurl.com/k6nzvtw
            AKA; Don'e, UD, Unca Don'e
            • Orange4
              • Sep 2013
              • 398
              Thanks. I don't know which model it came from. It was in a bin at the wreckers with about 50 other ACCTs. It had the most spring tension so I grabbed it. I could check if it has a P/N.
              Living to EXcess.
              • donebysunday
                • Oct 2012
                • 1737
                • New Berlin, Wi.
                Might be you found the special fit one that will keep us from screwing up our valves ????
                Maybe someone here can identify that one ? T.I.A. Don'e };-)
                76 XS650 C ROADSTER
                80 XS 1100 SG
                • DeanR
                  • Jan 2005
                  • 1499
                  • Finger Lakes NY
                  Mine is from a Raptor and does not do that. Have yet to install it.
                  80 SG
                  81 SH in parts
                  99 ST1100
                  91 ST1100
                  • donebysunday
                    • Oct 2012
                    • 1737
                    • New Berlin, Wi.
                    OK ! So am I right or wrong on this ACCT being the saving grace ? I understand it still comes down the op/error, but could this take a step out of the night mare of possibly bending valves ?
                    Orange how easy was it for you to install ?
                    76 XS650 C ROADSTER
                    80 XS 1100 SG
                    • BigOates
                      • Mar 2013
                      • 71
                      • Montgomery, Al.
                      I've got the same exact one on both my bikes. Mine came as a two 'fer off of a 1985 Yamaha XVZ 1200 D Venture Royale. Probably could look up the part no. off that fiche and cross reference. Nice tip btw.. I have been just fully unscrewing that bolt and replacing it on the tensioner after it was installed on the bike! It's as easy to install as the original. A direct bolt in replacement for me.
                      Jason
                      Montgomery, AL
                      80 XS1100SG Daily Driver
                      81 XS1100SH (Getting ready for an engine rebuild)
                      86 Honda Magna V45 (sold)
                      • BigOates
                        • Mar 2013
                        • 71
                        • Montgomery, Al.
                        Ok, I decided not to be lazy. The Yamaha part number is: 26H-12210-03-00
                        Looks like it was used on the VMax as well. Still available new if you've got money to burn or they're pretty cheap on ebay.
                        http://www.boats.net/parts/detail/ya...210-03-00.html
                        Jason
                        Montgomery, AL
                          Wow.. pretty awesome find. Thanks! Every time I've installed these, (And yes, they're from the Venturer) trying to get that big bolt to start under full spring tension was a tightrope walk between kung-fu and cussing. Then, just about the time you think you have a thread or two grabbing and you let go.. PEW! Shoots it out and laughs at you. (This is usually where the cussing is most helpful).
                          What makes it worse, is just to make sure this all stays drip-free from oil, I put some form of liquid gasket on both sides of that brass washer (Yeah, I know, probably a crush washer and doesn't need it, but just insurance) and it has always made a mess before getting it to go.
                          I bow to the Orange!
                          Now if we can just get a video of you pulling that nail off... lol
                          • Orange4
                            • Sep 2013
                            • 398
                            You are welcome! My OCD actually comes in handy sometimes.
                            Done, I have not installed it yet using this trick on my running bike but it seems this will make that a lot easier.
                            The reverse thread is brass on mine. Here's a pic of what to look for if you are going to the wreckers:
                            Living to EXcess.
                            • Orange4
                              • Sep 2013
                              • 398
                              The nail thing. Is this going to be some kind of defining moment for my identity? Oh well. Here goes anyway.
                              So... after I used my thumb to stop a speeding train, it was bruised so far under the cuticle that it stopped growing long enough for there to be a gap behind the surviving portion at the front. The blood blister (which I holed on my drill press to relieve the pressure. harrgh!) left a space under the nail as well so there's this great void for all manner of things to get caught on or under which hurt all over again. It also looked horrible. My wife called it "Frankenthumb". So she suggested I go get it repaired at her nail salon. Go to the nail salon? Ummm, how about no? Is no good for you, dear?
                              It was bugging me for days after that and it got caught on a thread one day and just about finished the job so I rode down to the salon later that day and sneaked in to get it done. Once inside I took off my dark glasses and I noticed how cute the nail girl was and I thought, how bad can this be? So she cut and filed and glued a patch on my nail and then asked what color polish I wanted. Well, I was so relaxed from all that attention, pampering and gossip that it took me by surprise. I put down my pumpkin spice latte and said, Huh? Polish? What's the manliest color you have? It was at this point that I realized that metal flake is just glitter for guys. Did I choose glitter orange as you might have hoped? No. I chose flat black because that's punk right? And manly.
                              So that's how I ended up with a fully black nail and got a hand job from a cute girl who was not my wife.
                              True story.
                              And now back to manly tensioner installations...
                              Living to EXcess.
