Petcocks
  • mack
    • 2411
    • Ontario, Canada
    Petcocks
    Been thinking lately about the plumbing for this E. Is there any advantage to the vacum petcocks on the standard tanks over the gravity feed that the specials have when the octy is removed? I think I want to reduce the network and simplify.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    • 8052
    Special petcocks won't fit due to different spacing. You can use similar year aftermarket XS650 petcocks from Mike's XS or adapter plates and universal petcocks from Parts-N-More. The quality of the aftermarket stuff is questionable and the stock petcocks will last for a very long time if you build them properly.
    • mack
      • 2411
      • Ontario, Canada
      I have two sets of stock
      petcocks here but they aren't in very good shape. The aluminum is soft, almost rotten I'd say ,covered with white powder. I've cleaned them a couple times but the powder keeps coming back.
      I was wondering if there was any advantage to keeping the vacum style. I'm sure I can get a gravity feed assy that will fit and be able to do away with two hoses and just cap off the intake boots.
      mack
      HERMES
      original owner
      81 XS 1100 LH MNS
      SPICA
      78 XS 11E
      IOTA
      613-398-6186
        • 8052
        Yes. You have those options listed, as well as others. You may also come up with good used ones.
          Advantages to keep are safety........fuel shuts off when engine does, tip-over etc.
          Float needles that may not be tottally sealing off
          An aging memory that forgets to shut fuel off when not riding.
            Thanks Brant for reminding us why auto petcocks are so nice
              • 2074
              Did you inquire about Pingel?They make petcocks- a little pricey but well worth it.
              • foreda
                • 949
                • Southwest Louisiana
                Pingel
                Pingel makes vacuum operated valves but I think fitment may be an issue because of the adapter you would need to install on the 11. I have one on my 82 CBX 1000 and it works great.
                Dale
                78 XS1100E Standard
                Coca Cola Red
                Hooker Headers
                http://i408.photobucket.com/albums/p...m/DSC00580.jpg
                1979 XS1100 Special
                http://i408.photobucket.com/albums/p...m/DSC00612.jpg
                1980 XS Standard
                http://i408.photobucket.com/albums/p...m/DSC01137.jpg
                2006 Roadstar Warrior
                http://i408.photobucket.com/albums/p...um/warrior.jpg
                  • 2074
                  I got a set on my 80 SG.they were rebuilt once by Pingel.Great part though.
