Headlight relay
  • Headlight relay
    80 model xs11sg.....headlight relay went south......quit working.....replacement price looks way high for a small part........relay#1469d.....any ideas for replacement,conversion,or modificatin...thankz a mil
    Here is some information that you might find useful. I took out the relays in all three of my xs11's:
    http://home.earthlink.net/~sidskids/relay/relay.htm
      Headlight relay
      Skids......thanks for the info.....any numbers on that five pin relay?
        Re: Headlight relay
        No. I got it at Autozone near the auxiliary lighting department. It is a "30 amp" lighting relay. I just slid the ond one off of the prong, and drilled a hole in that prong to mount the new one. It is probably the closest thing located near the steering head tube. I think if you removing the reserve lighting unit, the running lights will also be switched... There is a link on that same website to do that.
          "I just slid the ond one off of the prong"
          That should read, "I just slid the old one off of the prong"
            Skids.......thanks again.Nice web site,Saved $61+ so I guess it's time a new tire........later
