Headlight relay
  • jackstarr
    • 7
    • Nampa,Id
    Headlight relay
    80 model xs11sg.....headlight relay went south......quit working.....replacement price looks way high for a small part........relay#1469d.....any ideas for replacement,conversion,or modificatin...thankz a mil
    • 5058
    Here is some information that you might find useful. I took out the relays in all three of my xs11's:
    • jackstarr
      • 7
      • Nampa,Id
      Headlight relay
      Skids......thanks for the info.....any numbers on that five pin relay?
        • 5058
        Re: Headlight relay
        No. I got it at Autozone near the auxiliary lighting department. It is a "30 amp" lighting relay. I just slid the ond one off of the prong, and drilled a hole in that prong to mount the new one. It is probably the closest thing located near the steering head tube. I think if you removing the reserve lighting unit, the running lights will also be switched... There is a link on that same website to do that.
          • 5058
          "I just slid the ond one off of the prong"
          That should read, "I just slid the old one off of the prong"
          • jackstarr
            • 7
            • Nampa,Id
            Skids.......thanks again.Nice web site,Saved $61+ so I guess it's time a new tire........later
