counter shaft washer swap
  • mack
    • 2411
    • Ontario, Canada
    Anyone but me find that second gear is bound up after doing the washer swap?
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
  • Rasputin
    • 3189
    • Lacombe, Alberta, Canada
    Have only done it twice on my bikes and a third time on another members bike, so far, but no complaints on that issue.
    2-79 XS1100 SF
    2-78 XS1100 E Best bike Ever
      • 2066
      Mack:
      Don't have experience with the washer swap yet, but wondering what "bound up" means. Does it mean it is stuck in second gear?
      • mack
        • 2411
        • Ontario, Canada
        Bound
        It just doesn't spin on the shaft freely like it should. Like the first or third gear, you can turn it but not spin it like it should! Maybe I distorted the clip, I had heck of a time working it out.
        mack
        HERMES
        original owner
        81 XS 1100 LH MNS
        SPICA
        78 XS 11E
        IOTA
        613-398-6186
          • 8802
          Yes, the clip can get distorted and cause that gear to bind, hammer it flat before installing on the countershaft. Make sure 2nd gear spins freely, it may affect shifting otherwise.
          • mack
            • 2411
            • Ontario, Canada
            Tool
            there must be a tool to remove those flat clips without distorting them. Got a link?
            mack
            HERMES
            original owner
            81 XS 1100 LH MNS
            SPICA
            78 XS 11E
            IOTA
            613-398-6186
              • 1916
              I have not
              done this as of yet either but a thought came to mind. May be way off base but curiosity makes me ask. If the washer is distorted and binding ... is that because of how tightly it sits on the shaft? If that is true couldn't the inside diameter of the washer be made larger to give it more play so that it does not sit so tightly? I was thinking that the whole purpose of the washer is to limit lateral movement of the gear while engaged so having a little more play on the inside circumference shouldn't cause any problems other then a bit more vibration/ i.e. chatter possibly but I think that would be at a minimum. JAT and how far out there am I?
                • 1916
                OK reread the thread.... what does the clip you are talking about look like? I was assuming clip and washer were one in the same. I am curious because this sounds like a good proactive mod to perform before the 2nd gear problems arise. Pictures would be great if you have them.
                • mack
                  • 2411
                  • Ontario, Canada
                  Pictures
                  Give me few minutes and I'll take some and post them. The washer swap has been around for a long time, first done by Bob Jones, so I know it should be easy and work like a charm. He did recommend doing this as preventive maintnance. It just allows 2cd and 5th gears a little more contact(width of washer) to prevent skipping. The issue is really, how to get the darn clip in and out of the recess without distorting it. There has to be a good tool for this something like a set of pliers or a piston ring tool.
                  mack
                  HERMES
                  original owner
                  81 XS 1100 LH MNS
                  SPICA
                  78 XS 11E
                  IOTA
                  613-398-6186
                  • ViperRon
                    • Feb 2011
                    • 1062
                    • Woodstock, VA
                    Tool
                    Had a tool like this was the best at E clips removal and insertion http://www.tecratools.com/product950.html
                    Rodan
                    1980 G Silverbird
                    1198 Overbore kit
                    Grizzly 660 ACCT
                    Barnett Clutch Springs
                    R1 Clutch Fiber Plates
                    122.5 Main Jets
                    ACCT Mod
                    Mac 4-2 Flare Tips
                    Antivibe Bar ends
                    Rear trunk add-on
                      • 8802
                      It seems to me that when removing the clip is when it will distort. After straightening it, it can be carefully worked down into position without it bending. I have used a standard snap ring pliers to spread it during installation.
                      • mack
                        • 2411
                        • Ontario, Canada
                        Washer Swap
                        Here you go Cajun.
                        mack
                        HERMES
                        original owner
                        81 XS 1100 LH MNS
                        SPICA
                        78 XS 11E
                        IOTA
                        613-398-6186
                        • mack
                          • 2411
                          • Ontario, Canada
                          oops
                          mack
                          HERMES
                          original owner
                          81 XS 1100 LH MNS
                          SPICA
                          78 XS 11E
                          IOTA
                          613-398-6186
                            • 9980
                            The gear seems tight because there's a bevel cut into the gear that matches the angle that's machined into the shaft itself when the gear is in it's stock position. The washer doesn't so it feels a bit tight. It isn't an issue if you assemble it like that because after the first couple of miles running it seats in.
                            I've taken the shaft and positioned it with the gear in place protected from being damaged and seated the washer on the shaft with a few good licks of a hammer. That helps some if your worried about it but as I stated, it really isn't an issue.
                            • mack
                              • 2411
                              • Ontario, Canada
                              Stupid
                              Now just feel stupid. After taking the main shaft apart to remove the rust, look what I found. The perfect solution to removing and installing those clips. The one on the left is from the countershaft, right is between the fourth and 2/3 pinion. Simple but elegant.
                              Why they didn't do that for the countershaft is anyones guess!
                              mack
                              HERMES
                              original owner
                              81 XS 1100 LH MNS
                              SPICA
                              78 XS 11E
                              IOTA
                              613-398-6186
