Low Compression Issue
  • PMKXS11
    • Mar 2013
    • 100
    • Rockford, Il.
    Found these:
    http://www.ebay.com/itm/Wiseco-W2723...-/321516300693
    http://www.amazon.com/HEAD-GASKET-YA.../dp/B008YEH69M
    It matches the part number that Wiseco provides in their 1196 kit
    http://www.wiseco.com/ProductDetail....979&AppID=8824
    '79 Yamaha XS11 SF (project)
    '11 Harley Nightster (street)
    '03 KTM 125sx (dirt)
    '03 Suzuki GSXR-600 (track)
    '73 Jawa Californian (collecting dust)
    • PMKXS11
      • Mar 2013
      • 100
      • Rockford, Il.
      I decided not to bother trying the RTV because who knows how long that'll last for, so I pulled the head completely off and there was indeed a tear in the front of the gasket. Out of curiosity, I pulled out the stock head gasket to compare it to the Wiseco one and they're not that far off. The Wiseco is in the foreground and the "stock" is behind it. Can I chance it or just order a Wiseco replacement?
      • Briggs&Stratton
        • Mar 2014
        • 47
        • Grand Forks, ND.
        I'm no help with your gasket issue, but your engine setup has my interest. What kind of horsepower would you expect to see the way this was built?
        79 SF
        IG "9mmHeater"
          Hey PK
          I am assuming that the stock was used / i.e. compressed and the wiseco is new? If that is true might be what is causing the difference in your comparison.
          • CaptonZap
            • Jun 2010
            • 1748
            • Denver
            Take the gasket with the smaller diameter and lay it on top of the cylinder block. If the metal ring protrudes into the combustion chamber, I would advise that you not use it.
            The metal is the fire stop, and it needs "full body contact" to transfer the combustion heat to the block and head. If it does not have that full contact, it will cause a hot spot in the combustion chamber, leading to all sorts of bad things happening to the engine.
            Can you say detonation? Pre ignition?
            It hurts to have to buy another gasket, but it is cheaper than repairing the damage caused by improper assembly.
            CZ
            • PMKXS11
              • Mar 2013
              • 100
              • Rockford, Il.
              No idea, she'll get thrown up on the dyno when she's done though, I an very curious to see what she can do.
              Another gasket has been ordered, should be in today actually, damn job getting in the way of working on the bike
