Matching Mixture levels 4-5K RPM
    Originally posted by skids
    You took the words right out of my fingers Ian.
    I'll try but it usually takes about 15 minutes or so to get the adjustments done.
    The other thing about the larger pilot hole is, you may get popping on deceleration when you get it running right. At least that is the way mine was. I don't think it "mists" to fuel properly and is more of a drip. With mine, I cared more about getting the idle right, than the midrange when I adjusted pilot screws (and vacuum synched of course).
    The midrange (1/4 to 3/4 throttle) has very, very little to do with the pilot screws. The midrange is fed through the 3 small holes behind the throttle plate and metered by the pilot jet.
    The popping is caused by a LEAN condition on decel. That's the only time I will mention counting turns on the pilots. After all the vacuum adjusting I've found that it leaves the idle mixture just slightly lean (popping slightly on decel) so an extra 1/4 to 1/2 turn open puts it pretty much right where it should be.
    • BillyRok
      • Aug 2011
      • 421
      • Shortsville, NY.
      This is what it says towards the bottom of that Ebay listing for the gauges---
      Parts included in the Kit:
      1 qty x Bracket
      4 qty x 2 & 3/4" Gauges
      4 qty x Hoses 4mm(.I.D)x7mm(O.D.)x75cm (L)
      4 qty x plastic Valves 5.5mm(O.D.)
      2 qty x 180mm(M5xP0.8) Brass Extension
      2 qty x 65mm(M5xP0.8) Brass Extension
      The gauge is universal tool, it only contains 5mm adapters for most Honda, Suzuki; buyer needs to buy additional 6mm adapter for yamaha.
      comes with a mold storage case
      What does the part in red refer to?
      Billy
        • 3956
        Don't worry about that. Our intake manifolds do not use threaded nipples. So, don't worry about buying them.
        • CaptonZap
          • Jun 2010
          • 1748
          • Denver
          If you have a 650, you need two of them.
            Yeah, those come with it but are for another application.
