79 Special Intermittent Ignition cut out
  • 79xs1100s
    • Aug 2009
    • 115
    Hi,
    I do not know if they are genuine parts, I had them sonic cleaned, rebuilt and visually restored. I did replace the needles with the Viton tipped ones with matching seats after I got them back. I'm shying away from the carbs because the fault is intermittent, or at least only once it gets warm, but I could be so far from correct with that assumption.
    I just rode it again and it is surging at idle when hot, bogging and back firing.
    XS11.Com resident Black Sheep
    • MPittma100
      • Aug 2011
      • 2359
      Intermittent
      May want to run a valve clearance check. Also run a compression/cylinder leakage test.
      MP
      1981 XS1100H Venturer
      K&N Air Filter
      ACCT
      Custom Paint by Deitz
      Geezer Rectifier/Regulator
      Stebel Nautilus Horn
      EBC Front Rotors
      Limie Accent Moves On In 2015
      Mike
      • James England
        • 3039
        • North of England
        Originally posted by 79xs1100s
        Hi James,
        I was planning on ordering the dynas tomorrow once I get paid. They run about $118 Shipped this side of the lake.
        $210 over here!
        • 79xs1100s
          • Aug 2009
          • 115
          #34
          James that's awful!
          I just ordered the Motion Pro tool to check the valve clearances. I probably won't have this girl back on the road this year at this rate
          • 79xs1100s
            • Aug 2009
            • 115
            #35
            Well a few more updates for continuities sake.
            I had installed new exhaust gaskets before this season and thought after some riding they may have seated in and needed to be tightened. I tightened my exhaust nuts, which weren't all that loose.
            I re wired all of the pick up wires on the timing advance, and bumped the Idle up a little on the high side just to rule it out.
            I was able to take it out last night for about 30-35 miles with no major issues, I think the carbs need to be synced but they aren't bad. Temps last night were about 45 degrees. The last time I rode it with issues the temps were around 75-80. I'm hoping it wasn't just running better because it new got on the over hot side
            • FANNING507
              • Jul 2008
              • 103
              • south central Kansas, Turon
              #36
              Might want to pull out the multimeter
              I had the same thing happen to my bike. One of the coils went bad, but didn't show up until it warmed up. There is a thread here that shows how to check if the coils are good using a multimeter. An old mechanic said to replace both while you are at it. Andreas provided me with replacements and they work fine.
              '81 XS11 LH (MNS)
              "On a scale of 1 to 10, I have an eleven!"
              "Excess is easier to say than XS,"
