I have the subject bike and have not started it recently. No problems in the past but I now have "no spark". That is no spark on all four cylinders. It spins and turns over fine and there is gas to the carbs. I am using a jumper to boost the battery, checked fuses, disconnected the tip over switch, checked some connections, have not checked the coils (but it is all four) and I am suspect of the TCI. It seems, logically, that something is affecting all four cylinders. What would be in common with all four to result in no spark? The normal spark is not that exciting and not easy to see but I am checking in a relatively dark garage.
gene in FL
gene in FL
.........here visiting in GA. right now, I can definitely see where the moisture and humidity in parts of the country is definitely the killer of electrical connections
