Gene,
The 1980G Standard electrical system is almost identical to your 1980LG Midnight Special but the differences may confuse things so here's a link to a color wiring diagram for your bike:-
1980 XS1100SG/LG and 1981 XS1100SH/LH
For the no-start problem: have you checked the pick-up coils/connectors? They should both be at about 720 Ohms. If they're much higher, lower or open circuit, make sure the connectors at the TCI and behind the Fuse Block are clean, plugged in and tight. Suddenly losing spark to all four cylinders sounds to me like a loose connector, broken wires or a bad Ballast Resistor.
There is also an Ignition bypass wire from the Start Solenoid that bypasses the Ballast Resistor to feed a full 12V or more to the Ignition Coils when the starter is cranking the engine.
You've found one of the more common dirty/corroded connections -- the Ignition Switch and its connector. I don't believe that's causing the 'no start' problem but the switch and connectors will have to be cleaned up or they'll slowly get worse, then the bike won't start and it'll run badly if it does.
All of the Brown wires at the 'top' of the stock XS1100 Fuse Block and the Alternator Field Coil are spliced onto the one, single, Brown wire that comes down from the Ignition Switch.
As T.C. wrote, even with the Field Coil is connected a good battery should be able to keep the system voltage well over 12 Volts when the engine is not running. Charge the battery and unless it's a sealed or AGM battery, check the specific gravity in each cell.
Well, the XS1100 Voltage Regulator/Rectifier does exactly the same thing any other Voltage Regulator/Rectifier.
The XS1100 charging system is very similar to a Chrysler/Plymouth charging system.
The Rectifier section has a diode bridge to convert 3Phase AC current from the Alternator into DC current for charging the battery and running the rest of the vehicle electrical load. The XS1100 uses an external diode bridge in the Regulator/Rectifier and it's bolted to the frame under the fuel tank instead of inside of the alternator.
The Voltage Regulator section regulates the amount of current going through the Alternator Field Coil and keeps the Alternator output voltage somewhere between 12V DC and 14.5V DC.
