I am stumped
  • 79XS11F
    • Jul 2006
    • 3563
    • Ottawa, Ont. Canada
    #121
    Rob,
    Are there any repairs in the pickup circuit? If so, I'd start there.
    I already have them swapped out with the ones from the modified bike. I remember now that when I built the modified bike I took the NOS pick ups from the restored bike because I wanted the modified bike to be "perfect". Perhaps my issue will be addressed with this switch back. If this does correct my issue I will cut the wire harness off the other set and see if there are any breaks of weakness's within the entire length of that harness.
    In the mean time because the bike is apart I am also addressing a small oil leak at the valve cover and bleeding the front brakes. I will know by days end if I have things sorted out.
    Rob
    KEEP THE RUBBER SIDE DOWN
    1978 XS1100E Modified
    1978 XS500E
    1979 XS1100F Restored
    1981 Suzuki GS1100
    1983 Suzuki GS750S Katana
    1983 Honda CB900 Custom
    • 79XS11F
      • Jul 2006
      • 3563
      #122
      No change
      So to date I have tested with:
      different TCI boxes,
      different coils and high performance coils
      different pick up coils
      different and new spark plugs
      different plug caps
      different carbs
      new fuel
      full charged battery
      So, I guess this is as good as it gets and that's that. I now wish I had taken the 5k I was offered for this bike last summer ....
      1978 XS500E
      1981 Suzuki GS1100
      • Rasputin
        • 3192
        • Lacombe, Alberta, Canada
        #123
        JAT but what is your pick up coil gap set too?
        2-79 XS1100 SF
        2-78 XS1100 E Best bike Ever
        • 79XS11F
          • Jul 2006
          • 3563
          #124
          I'll check that for fun next time I have time to work on it.
          I intend to use it as is for nothing other then around town recreational use. I'm so discouraged at this point that I am seriously considering parting it out. I have spent enough money on this bike to own something much newer and much more reliably.
          Rob
          1978 XS500E
          1981 Suzuki GS1100
          • Jeffintampa
            • Apr 2011
            • 344
            • Zephyrhills, Florida
            #125
            almost ready to get rid of mine to
            These carb problems got me thinking of 4 wheels again also
            Bike History:1980 XS 1100 special current bike
            1980 XS 850 special wife sold
              • 8054
              Something is wrong. You just haven't found it.
                • 8863
                My bet is dielectric grease. No need to clean all connections over, I would just unplug them all and plug them back in. I fixed mine on the side of the road that way when 2 cylinders cut out.
                  • 8054
                  Unless there is actually silicon dioxide formed on a connector.
                  • 79XS11F
                    • Jul 2006
                    • 3563
                    #129
                    There's not much of the tune up grease down in the connections. I just smeared at across the face of each block connection as I assembled them.
                    Rob
                    1978 XS500E
                    1981 Suzuki GS1100
                    • 79XS11F
                      • Jul 2006
                      • 3563
                      #130
                      So I was out last night for a run and she is missing worse than before. Cant hold and consistent RPM and really get erratic above 5K
                      Rob
                      1978 XS500E
                      1981 Suzuki GS1100
                      • Blank Slate
                        • Nov 2013
                        • 392
                        • Ottawa, Ontario, Canada
                        #131
                        Well Rob, you have 7 other bikes to play with.
                        Is the '79 your favorite?
                        Frame: 79 XS1100S
                        Engine: 81 XS1100S
                        Carbs: 78-79 BS34
                        Gf bike: 78 XS650S
                        Carbs: 70-79 BS38
                          #132
                          Hey Rob,
                          I didn't go back and reread the whole thread, but I think I remember you saying you swapped carbs as well. Did you take OFF the intake boots, inspect, clean their connection/mounting surface to the head, as well as the intake boot caps? JAT?
                          • 79XS11F
                            • Jul 2006
                            • 3563
                            #133
                            Hey Rob,
                            No I didn't TC but spraying quick start around the carbs and boots etc does not result in any RPM increase so I'm pretty sure they are sealed.
                            I just exchanged a few messages with Mack who gave my carbs the once over and he tells me he found no issue with them.
                            This means the issue is ignition / electrical related so now I really don't know what to look at next.
                            I guess I will have to check every connection and component one by one if I ever find the time.
                            Rob
                            1978 XS500E
                            1981 Suzuki GS1100
                            • 79XS11F
                              • Jul 2006
                              • 3563
                              #134
                              Only my 79 is insured for use and with a current plate sticker. Only 4 of the others could be made road ready for the cost of batteries, oil and tune ups.
                              Rob
                              1978 XS500E
                              1981 Suzuki GS1100
                                Rob
                                .......pretty much follows 'rule of thumb'..........pri./sec. ignition before fueling is 99.5% good advice for tracking a running issue. Very little time needed to check all the notorious locations, under tanktop left side of frame plug-in that voltage is spot equal to voltage across that plug-in as batt. voltage, key on of course. If not, kill switch needs to come apart and ALL of it including switch dropped in EvaporRust. Makes the switch insert bright again like new. Ignition switch contacts is your other source that is common for voltage drops, in that circuit. Should be taken apart and cleaned same way, but I cheated and removed the little tin protector cover off bottom of switch and sprayed vigoriously, electrical contact cleaner till all the dark crud rolled out. Realize that some of that was old lube, but gave me the location of a missing 1 1/2 volts. The other 1 1/2 missing volts was at the kill switch.......problem solved. Hope this helps you 'shelve' the frustrations.
