I am stumped
    replied
    Bypass the KILL SWITCH for a start. Two wires under the tank, right side. If the problem goes away, you found it, if not, on to the next connection.
    Leave a comment:
    replied
    Originally posted by 79XS11F
    No I didn't TC but spraying quick start around the carbs and boots etc does not result in any RPM increase so I'm pretty sure they are sealed.
    I just exchanged a few messages with Mack who gave my carbs the once over and he tells me he found no issue with them.
    This means the issue is ignition / electrical related so now I really don't know what to look at next.
    I guess I will have to check every connection and component one by one if I ever find the time.
    Rob
    .......pretty much follows 'rule of thumb'..........pri./sec. ignition before fueling is 99.5% good advice for tracking a running issue. Very little time needed to check all the notorious locations, under tanktop left side of frame plug-in that voltage is spot equal to voltage across that plug-in as batt. voltage, key on of course. If not, kill switch needs to come apart and ALL of it including switch dropped in EvaporRust. Makes the switch insert bright again like new. Ignition switch contacts is your other source that is common for voltage drops, in that circuit. Should be taken apart and cleaned same way, but I cheated and removed the little tin protector cover off bottom of switch and sprayed vigoriously, electrical contact cleaner till all the dark crud rolled out. Realize that some of that was old lube, but gave me the location of a missing 1 1/2 volts. The other 1 1/2 missing volts was at the kill switch.......problem solved. Hope this helps you 'shelve' the frustrations.
    Leave a comment:
  • 79XS11F
    replied
    Originally posted by Blank Slate
    Well Rob, you have 7 other bikes to play with.
    Is the '79 your favorite?
    Only my 79 is insured for use and with a current plate sticker. Only 4 of the others could be made road ready for the cost of batteries, oil and tune ups.
    Rob
    Leave a comment:
  • 79XS11F
    replied
    Hey Rob,
    I didn't go back and reread the whole thread, but I think I remember you saying you swapped carbs as well. Did you take OFF the intake boots, inspect, clean their connection/mounting surface to the head, as well as the intake boot caps? JAT?
    Rob
    Leave a comment:
    replied
    Hey Rob,
    Leave a comment:
  • Blank Slate
    replied
    Leave a comment:
  • 79XS11F
    replied
    So I was out last night for a run and she is missing worse than before. Cant hold and consistent RPM and really get erratic above 5K
    Rob
    Leave a comment:
  • 79XS11F
    replied
    Unless there is actually silicon dioxide formed on a connector.
    There's not much of the tune up grease down in the connections. I just smeared at across the face of each block connection as I assembled them.
    Rob
    Leave a comment:
    replied
    My bet is dielectric grease. No need to clean all connections over, I would just unplug them all and plug them back in. I fixed mine on the side of the road that way when 2 cylinders cut out.
    Leave a comment:
    replied
    Leave a comment:
    replied
    Something is wrong. You just haven't found it.
    Leave a comment:
  • Jeffintampa
    replied
    almost ready to get rid of mine to
    These carb problems got me thinking of 4 wheels again also
    Leave a comment:
  • 79XS11F
    replied
    I'll check that for fun next time I have time to work on it.
    I intend to use it as is for nothing other then around town recreational use. I'm so discouraged at this point that I am seriously considering parting it out. I have spent enough money on this bike to own something much newer and much more reliably.
    Rob
    Leave a comment:
  • Rasputin
    replied
    JAT but what is your pick up coil gap set too?
    Leave a comment:
  • 79XS11F
    replied
    No change
    So to date I have tested with:
    different TCI boxes,
    different coils and high performance coils
    different pick up coils
    different and new spark plugs
    different plug caps
    different carbs
    new fuel
    full charged battery
    So, I guess this is as good as it gets and that's that. I now wish I had taken the 5k I was offered for this bike last summer ....
    Leave a comment:
