My restored 79 XS11 Standard is not running right. It is missing at idle, during acceleration, and at any held speed in any gear. She pretty much is running on 3 cylinders with # 2 appearing to be where the issues is.
To date I have:
- Cleaned the carbs about 5 times including putting parts and bodies through an ultra
sonic cleaner.
- Confirmed float levels as within spec (set all at 1 inch)
- Confirmed that the fuel tank air intake is working.
- Used new gas.
- Confirmed that the petcocks are working properly.
- Confirmed that the coils are good by installing a set of excell coils from my other bike.
- Confirmed that the pick up wires are good.
- Confirmed that the timing is good.
- Confirmed that the ignition unit is working by switching it out for a known good unit from my other bike.
- Sprayed quick start around carbs while idling with no change so no air leaks.
The bike still will not run right. I think I will give her a complete tune up and carb cleaning again but I am not holding out much hope that this will result in a running bike.
She ran very well for 2 years after being restored. The 3rd spring she developed this issue and I have had no luck sorting her out. Any suggestions would be appreciated. I must be missing something and maybe it s so obvious I can see it.
Rob
