I am stumped
    what does JIS mean???
    J-apenese I-ndustrial Steel
    • CaptonZap
      • Jun 2010
      • 1748
      • Denver
      #227
      Originally posted by 79XS11F
      Yeah I know they are different. I will ether have to go out and buy a JIS driver or find my best fit Philips and grind the tip down a bit. They are always shallower then true Philips and I really don't want to damage them.
      For those who don't know, when you see a Philips screw and there is a single dot or sometimes an X on the head of the screw, it indicates that the screw is JIS which I think stands for Japanese Industry Standard. It's slightly different then a Philips.
      Rob
      The $1.99 on sale 4 in 1 blue handled screwdrivers at Habba Fleight are just what you need for those screws.
      http://www.harborfreight.com/4-in-1-...dle-69470.html
      CZ
      • mack
        • 2411
        • Ontario, Canada
        #228
        cheaper option
        take a small drill bit and just deepen the hole a tad in center of the philips X
        mack
        79 XS 1100 SF Special
        HERMES
        original owner
        81 XS 1100 LH MNS
        SPICA
        78 XS 11E
        IOTA
        https://youtu.be/wB5Jfbp6SUc
        https://youtu.be/RaI3WYHSuWA
        Frankford, Ont, Canada
        613-398-6186
          #229
          Make that Japanese Industrial Standard
          • 79XS11F
            • 3563
            • Ottawa, Ont. Canada
            #230
            Hey Rob,
            It's not just that they are JIS, but also...I'm sure you know this, moreso stating for other newbies that may read this thread....the ends of the screws are PEENED to keep them from working loose and getting sucked into the engine. SO.....you'll need to use your dremmel to remove the peened portion of the screws before trying to loosent them....should allow you to loosen them easier and even with STANDARD philips driver. You'll just want to use some RED locktite when you put them back in.....or get some new ones so you can PEEN them again!?
            I knew they are peened but I was under the impression that they could be loosened just not removed without cutting the heads ends off.
            KEEP THE RUBBER SIDE DOWN
            1978 XS1100E Modified
            1978 XS500E
            1979 XS1100F Restored
            1981 Suzuki GS1100
            1983 Suzuki GS750S Katana
            1983 Honda CB900 Custom
            • 79XS11F
              • 3563
              #231
              The issue has been found, corrected and the bike is idling pretty good with the carb sync done. There's still an occasion back fire as compared to a miss and I will look into that when the season is done.
              So the "ghost in the machine" was this space between the end of the shaft and the washer on the spring side of the carb. The space is just wide enough for the spring to slip into and jam it up enough to prevent full closing of the butterfly valve.
              To fix it I loosened off the Butterfly screws, remove the fold over washer and nut from the opposite side of the shaft, slid the shaft over that much and used a washer to make up the space on the other side. It's not a "perfect" washer so that bolt is now firm hand tight and held in place by the fold over washer.
              1978 XS500E
              1981 Suzuki GS1100
                • 4015
                I just learned at the shop a few weeks ago about machined washers for a designed spec., so now I know what you mean by a "perfect" washer.
                • s63921c
                  • 31
                  • green bay,wi
                  #233
                  congrats
                  Congratulations on finding the solution! I've been wondering what became of your issue...and great job in persevering to track it down and not give up! And thank you to all you guys that know and share so much of your knowledge and experience with these bikes-I would have sold mine long ago if it weren't for you all being so helpful. This forum is exceptional in my book. Thanks for sharing what you found!
                  1980 MIDNIGHT1100 RIDER.
                  TRACY
                  • 79XS11F
                    • 3563
                    #234
                    Just in from a quick around the neighborhood test run that includes speeds up to 120 KM/HR and she is running pretty good. Still the occasional miss but she is for sure running rich. I can hear her babbling in the mufflers when coming off throttle. Idle managed to get up to 1500 once she was fully warmed up so I had to dial that back to 1100 and the RPMs seem to float a little when the throttle is released.
                    Rob
                    1978 XS500E
                    1981 Suzuki GS1100
                    • Blank Slate
                      • Nov 2013
                      • 393
                      • Ottawa, Ontario, Canada
                      #235
                      Congrats Rob! After I pass my safety course in two weeks I'll insure my bike and drive down the road see you
                      Frame: 79 XS1100S
                      Engine: 81 XS1100S
                      Carbs: 78-79 BS34
                      Gf bike: 78 XS650S
                      Carbs: 70-79 BS38
                        • 6765
                        #236
                        That is awesome news Rob...glad you stuck with it...I always thought this was a carb issue...
                        2005 Honda SilverWing 600
                        2018 Honda PC-Xpress 150
                        • 79XS11F
                          • 3563
                          #237
                          I went for a run around the outskirts of the city yesterday evening after dark and the bike runs pretty good but still needs some work as she is running rather rich. She sounds like a bike with a jetting problem that would occur after putting a header on it. When I down shift or back off the throttle I can hear unburned fuel igniting in the mufflers so the timing must be off just a tad or the occasional miss is putting fuel into the exhaust system.
                          I also noticed that the neutral light is dimly illuminated without blinking. and I don't recall that from the past.
                          If the neutral light is dimly illuminated there must be an electrical leak somewhere in the system so I will have to track that down. Any ideas as to where that might occur? Maybe that is related to the miss I am still experiencing. I know that the neutral light lead does come out of the timing cover so perhaps this is a clue to the missing issue.
                          Rob
                          1978 XS500E
                          1981 Suzuki GS1100
                          • dbeardslee
                            • 4385
                            • Maineville, OH
                            #238
                            What do your plugs look like after the carb butterfly fix and running it around a bit?
                            • 79XS11F
                              • 3563
                              #239
                              They are inconsistent at best with #2 looking the richest. I'm going to grab new plugs today and put the color tune plugs in her to see what's up
                              Rob
                              1978 XS500E
                              1981 Suzuki GS1100
                              • 79XS11F
                                • 3563
                                #240
                                I may fully disassemble the carbs and ultra sonic clean them with lacquer thinner but I need to research that first to make sure I am not making a bomb in my garage. I could of course run the machine in the yard. I do know that some people do use flammable cleaners in these units.
                                Rob
                                1978 XS500E
                                1981 Suzuki GS1100
