Spark Plug gaps
    • 6763
    Spark Plug gaps
    Getting around to a tune up today for Swampgurl...buying the sparkplugs...do they come already gapped
    2005 Honda SilverWing 600
    2018 Honda PC-Xpress 150
  • James England
    • 3039
    • North of England
    Usually not. Having said that, I've always just put them in engines just as they come out of the box.
    • MPittma100
      • Aug 2011
      • 2359
      Tune up
      The gaps may or may not be correct out of the box. Definitely check them before installing.
      Mike
      1981 XS1100H Venturer
      K&N Air Filter
      ACCT
      Custom Paint by Deitz
      Geezer Rectifier/Regulator
      Stebel Nautilus Horn
      EBC Front Rotors
      Limie Accent Moves On In 2015
      Mike
      • rover
        • Jan 2004
        • 765
        • central WI (715)
        spark plug gap
        I side gapped mine about two years ago. Seemed to much improve the way the F idled and accelerated. There is a post on here somewhere that tells of how to do that. I was told the plugs would not last long. Now after about 10K, it is starting to run rough. I will pull the plugs tomorrow and check them out. Let you know then.http://www.xs11.com/forum/images/icons/icon11.gif
        79 F (Blueballs)
        79 SF (Redbutt)
        81 LH (organ donor)
        76 CB 750 (gone to MC heaven)
        rover has spoken
          • 6763
          Not rocket science to gap plugs been awhile since I've changed any...now indeed yo find the correct plugs locally...I have all the info...
          • jwhughes3
            • 2798
            • Home of the Alamo
            My new NGK plugs for Enterprise had to be regapped out of the box - at least a couple were off a bit we found so I am glad it was checked.
            John
            '81 XS1100H - "Enterprise"
              • 2138
              I always check them and almost always they are correct.
              But, you never know if they have been dropped, so that's why I always check them.
              • mjpxs11sh
                • Jan 2011
                • 299
                • N/E, Illinois
                if theyre in your hand why wouldnt you gap em? i dont get it unless your toolbox is missing a wire feeler gauge lol. i gap mine at .030. jat
                Max
                81 XS1100SH Black Beast Mutt
                Kerker 4/1
                stock carbs and air box.
                78 headlite, handle bars,
                1 set of ea-160/85mph guages,
                crash bars, cruise control
                Other 2 Wheelers
                78 XS1100E jet kit, Kerker 4/1, air pods, jet kit-RIP
                94 CBR1000F jet kit,Two Bros pipe, K&N Filter
                • donebysunday
                  • Oct 2012
                  • 1737
                  • New Berlin, Wi.
                  I always gap my NGK BP6ES, seem to always come a bit wide ?
                  76 XS650 C ROADSTER
                  80 XS650 G Special II
                  https://ibb.co/album/icbGgF
                  80 XS 1100 SG
                  81 XS 1100LH/SH DARKHORSE
                  https://tinyurl.com/k6nzvtw
                  AKA; Don'e, UD, Unca Don'e
                    NGK's come set close to .035 Ben......usualy have to tap ground strap down a bit.
                      • 6763
                      what a PITA just trying to find an autoparts store that has anything remotely close to NGK BP6ES...a local advance auto only has NGK 7333 which s supposed to be compatible...according to the listing here on this site...so I go okay lets get them...welll the store locally doesnt have them but the store in Raleigh does...so they can deliver them to my local store...But it took them all day to do it and i gave up waiting...a day wasted...will see if they came in tmrw. but geeeez
                      • XS 1100 Rick
                        • Nov 2013
                        • 39
                        • Lethbridge, Alberta, Ca.
                        I just did mine last weekend and bought some NGK BPR6ES the gaps were wide around .035 so I gap them to .030 the manual calls for .028 to .032
                        So in the middle for me and it runs great.
                        Rick
                        XS11E 1978
                        Past Bikes that I owned
                        H1 Kawasaki 500 1972
                        CB 750K Honda 1978
                        CB 750K Honda 1979
                        Triumph 500 Daytona 1968
                        Triumph 650 Bonny 1969
                          • 3950
                          Geeze, now I feel dumb and entitled. Never thought to check my plus, as I assumed they were always pre-gapped. I find them easily available at Advance, Auto Zone and O'Reilly's, as well as two small bike shops. I even got the NGK Irridiums @ Advance for $6/pc.
                            • 8891
                            NGK 7333 is the same as BP6ES. The plug will say BP6ES, the box will say 7333 which is the number the auto parts store uses.
                              • 6763
                              Thanks Phil...will get 'em in the morning....
