Calling all Studs!
    • 1987
    Nubian
    They sell two different sizes this page may show you what you want. they have two different no 15 parts... what you are looking for is probably the second listing and they are still $1.46 each.
    http://www.mrcycles.com/oemparts/a/y...der-head-cover
    part no. 95617-08625-00
      To repair my broken studs I used steel threaded rod cut to length and Stainless Coupling Nuts. I did not want to use SS for both rod and nut as then there is the risk of galling. Tinman905 did the installation as he had excavated the pesky broken stud for me.
        • 8894
        Another source, there are 2 listed, I think the 2nd one is the longer one, # 15 on parts fiche...
        • jwhughes3
          • 2798
          • Home of the Alamo
          On my broken stud on Great Ranger I broke off the extractor inside neccessitating a different approach. I used a 3/8" diamond core bit like this to drill around the stud using a constant water bath to clear the cuttings:
          Then chiseled out the free standing center section about 0.25" deep. I took a metric grade 8 bolt and ground the head to match the drilled portion - tapering it to fit tight when inserted. Used another diamond tipped dremel to cut holding grooves all around it, and used steel epoxy and drove it into the cavity till flush. As long as I don't crank hard down on it I don't think its going anywhere.
          I still need to cut it down to length a bit to match the other studs.
          John
          '81 XS1100H - "Enterprise"
