Calling all Studs!
  • Nubian
    • Apr 2011
    • 467
    • The Big East
    Calling all Studs!
    Apparently some models came with longer exhaust studs than others, I have an older set of Jardines that require them to be mounted on my 11H. Trying to find a part # for them.
    Anyone?
    BAMN!
    '81 XS1100H "Brutus"
    • 8891
    According to Yamaha, no longer available. Take one of your old ones and go to Ace Hardware, they have metric 8MM studs.
      • 1987
      don't know
      if these will help or not but I just found these http://www.ebay.com/itm/YAMAHA-XS-75...item3cd852d757
      • Nubian
        • Apr 2011
        • 467
        • The Big East
        Don't have an old one, my 11H has the shorter ones, what is the part # please?
        BAMN!
        • Nubian
          • Apr 2011
          • 467
          • The Big East
          Nice! But $100.
          I will email him and find out their length,
          BAMN!
            Go to the fastener store and get a stick of SS allthread, 8MM x 1.25 and make them any length you want.
            • Nubian
              • Apr 2011
              • 467
              • The Big East
              Have not had good luck with SS. They often seize on me, but that's usually with SS on SS. How will SS on steel fare? Especially with high heat.
              BAMN!
                That's how I've always fixed mine.
                Besides, it's SS on aluminum.
                • Nubian
                  • Apr 2011
                  • 467
                  • The Big East
                  copy that, Fastenal does not carry it, will this work also? or do you have an online source?
                  http://www.zoro.com/g/00151758/k-G19...FSpp7AodNgQAuA
                  BAMN!
                  • Nubian
                    • Apr 2011
                    • 467
                    • The Big East
                    Best method for removing exhaust studs? Cold or warm engine or what?
                    BAMN!
                      Cold engine, double nut method...
                        • 1987
                        check
                        out this page. http://www.mrcycles.com/oemparts/a/y.../cylinder-head
                        I believe you are needing part 12 which this site has listed as part no:
                        95617-08615-00 which they have listed as still available for $1.46 each.
                          • 8891
                          Nubian, could some shorter collars be somehow fabricated for the Jardine? I forget what they look like exactly, may be better than risking breaking off perfectly good studs? JAT
                          • Nubian
                            • Apr 2011
                            • 467
                            • The Big East
                            That would be my first choice if I could get the pipes apart.
                            BAMN!
                            • Nubian
                              • Apr 2011
                              • 467
                              • The Big East
                              What I need is the part # for the studs off a '79 11F, they are longer than the other years
                              BAMN!
