Something snapped! A diagnosis.
It just keeps comin'
Pack the drive shaft and wheel hub/final drive full of moly grease.
Put everything back together, and noticed that the rear brake caliper is grinding on the rotor.
Wondering whether I'm missing a spacer? The previous wheel was 17", and this one is 16", but I don't think that would cause the problem. The manual stated to take particular care about this washer (below), and I made sure I didn't lose it, but maybe I have it in the wrong place?
Brake wasn't grinding before, unsure why it would now. Thoughts?
79 SFComment
I would add that I don't believe it's the brake calipers malfunctioning. I looked at several threads pertaining to the calipers, "spooge hole," and I do not think that is the problem.
I think the problem is how I reassembled it, or perhaps a missing spacer/washer.79 SFComment
You're missing the spacer.....Last edited by James England; 07-29-2014, 06:08 PM.XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.Comment
The 17" wheel for the standard and the 16" wheel for the Special take different spacers on the axle.Greg
So I need to buy a spacer for this 16" wheel to fit, then?
Okay. I thought it was the other way around. Thanks.79 SFComment
Yup.......ouch!.....wrong or the wider spacer wheel side is missin, along with the spacer between the caliper stop bracket and swingarm being incorrect.
As cajun31 suggested, your gonna end up with matching wheel hubs unless corrected
81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
Hey Mes,
Why are you putting the 16" wheel on, you have a standard, and you'll end up with running a bit higher revs for the same highway speed if you use the 16" wheel. As I stated, you just need to UNBOLT the hub assembly from both wheels, and put the good hub onto the 17" wheel, and then you'll have the correct spacers and caliper bracket so things will fit right and won't rub!
That being said, the 16" gives you a few more choices for tires, and widths, and will also make getting "Off the line" a little easier, and will let the bike sit a little lower if you have a short inseam!
T.C.T. C. Gresham
True TC but the rear tire choices are VASTLY greater with the 16". To make the gear ratio the same the 750/850 FD swap will take care of that.Greg
Actually, I have a Special. The previous owner modified it to accept a Standard tank.Hey Mes,
I actually wanted to keep the 17" wheel, honestly, but the tire is shot. I figured I'd rather get it riding and use the good tire which came on the 16" wheel than let it go to waste. I'll get a 17" tire and switch the hub out this winter.
I'm about 6'5" so I do prefer the 17" as far as comfort and aesthetics go.
I'll have to find a spacer for it before I ride, I guess.79 SFComment
Do you think, if I found the dimensions (particularly, width) of that spacer, I could throw on a few from the hardware store that would match it until I get a replacement? A stopgap for, say, a week or so?Hey Mes,
T.C.79 SFComment
As you have
guessed, the wheel assy configuration is different from 16-17 inch. So what are you actually looking to do here. I'm confused a bit but can give you videos on either or. Tell me what you need?mack
79 XS 1100 SF Special
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
https://youtu.be/wB5Jfbp6SUc
https://youtu.be/RaI3WYHSuWA
Frankford, Ont, Canada
613-398-6186Comment
Well, I'm trying to reassemble the rear wheel, hub, final drive, etc. and I've found that I cannot do so without the brake dragging on the rotor.
It's a Special. The wheel the original owner had on it was a 17", but he also gave me a 16". I put the 16" on seeing as it has a fresh tire on it, and a working wheel hub (splines are good). I thought I was missing a spacer, since the 17" and 16" have different parts, but I'm unsure. Most of what I've read said that the 16" wheel on a Special should not need an extra spacer. I currently have (as seen in the pictures) the dust hub/spacer thing, the brake bracket, and the other bracket attached to the brake. Stumped. Wondering whether the owner modified the rear wheel setup or whether perhaps his running the 17" without that spacer is what caused the final drive/wheel hub issue in the first place. Regardless, I need to fix this 16" wheel to the bike.79 SFComment
That is what my setup looks like. The dust hub/spacer, the and the two brake brackets.79 SFComment
http://www.boats.net/parts/search/Ya...EEL/parts.html
I believe that I am missing part number 23 in the diagram. That's my best guess.79 SFComment
