Something snapped! A diagnosis.
  • mesmeridicus
    • Sep 2013
    • 74
    • Dayton, Ohio
    #106
    Originally posted by cajun31
    be aftermarket.... I was looking at some earlier xs11 pictures and they may indeed be stock... I would still pay attention to alignment. Hopefully you will find something as you clean everything up. I would just not feel comfortable without digging and finding the real reason for the issue. You don't just want to throw parts on and then end up with the same problem in short order.
    I was under the impression that they are stock. The bike is actually a Special; the previous owner modified the bike to accept a Standard style tank.
    I'll be watching it carefully. Thank you.
    79 SF
    • mesmeridicus
      • Sep 2013
      • 74
      • Dayton, Ohio
      #107
      It just keeps comin'
      Pack the drive shaft and wheel hub/final drive full of moly grease.
      Put everything back together, and noticed that the rear brake caliper is grinding on the rotor.
      Wondering whether I'm missing a spacer? The previous wheel was 17", and this one is 16", but I don't think that would cause the problem. The manual stated to take particular care about this washer (below), and I made sure I didn't lose it, but maybe I have it in the wrong place?
      Brake wasn't grinding before, unsure why it would now. Thoughts?
      79 SF
      • mesmeridicus
        • Sep 2013
        • 74
        • Dayton, Ohio
        #108
        I would add that I don't believe it's the brake calipers malfunctioning. I looked at several threads pertaining to the calipers, "spooge hole," and I do not think that is the problem.
        I think the problem is how I reassembled it, or perhaps a missing spacer/washer.
        79 SF
        • James England
          • 3039
          • North of England
          #109
          You're missing the spacer.....
            The 17" wheel for the standard and the 16" wheel for the Special take different spacers on the axle.
            • mesmeridicus
              • Sep 2013
              • 74
              • Dayton, Ohio
              #111
              So I need to buy a spacer for this 16" wheel to fit, then?
              Okay. I thought it was the other way around. Thanks.
              79 SF
                Yup.......ouch!.....wrong or the wider spacer wheel side is missin, along with the spacer between the caliper stop bracket and swingarm being incorrect.
                As cajun31 suggested, your gonna end up with matching wheel hubs unless corrected.
                  #113
                  Hey Mes,
                  Why are you putting the 16" wheel on, you have a standard, and you'll end up with running a bit higher revs for the same highway speed if you use the 16" wheel. As I stated, you just need to UNBOLT the hub assembly from both wheels, and put the good hub onto the 17" wheel, and then you'll have the correct spacers and caliper bracket so things will fit right and won't rub!
                  That being said, the 16" gives you a few more choices for tires, and widths, and will also make getting "Off the line" a little easier, and will let the bike sit a little lower if you have a short inseam!
                    True TC but the rear tire choices are VASTLY greater with the 16". To make the gear ratio the same the 750/850 FD swap will take care of that.
                    • mesmeridicus
                      • Sep 2013
                      • 74
                      • Dayton, Ohio
                      #115
                      Hey Mes,
                      Actually, I have a Special. The previous owner modified it to accept a Standard tank.
                      I actually wanted to keep the 17" wheel, honestly, but the tire is shot. I figured I'd rather get it riding and use the good tire which came on the 16" wheel than let it go to waste. I'll get a 17" tire and switch the hub out this winter.
                      I'm about 6'5" so I do prefer the 17" as far as comfort and aesthetics go.
                      I'll have to find a spacer for it before I ride, I guess.
                      79 SF
                      • mesmeridicus
                        • Sep 2013
                        • 74
                        • Dayton, Ohio
                        #116
                        Hey Mes,
                        Do you think, if I found the dimensions (particularly, width) of that spacer, I could throw on a few from the hardware store that would match it until I get a replacement? A stopgap for, say, a week or so?
                        79 SF
                        • mack
                          • 2411
                          • Ontario, Canada
                          #117
                          As you have
                          guessed, the wheel assy configuration is different from 16-17 inch. So what are you actually looking to do here. I'm confused a bit but can give you videos on either or. Tell me what you need?
                          mack
                          79 XS 1100 SF Special
                          HERMES
                          original owner
                          81 XS 1100 LH MNS
                          SPICA
                          78 XS 11E
                          IOTA
                          https://youtu.be/wB5Jfbp6SUc
                          https://youtu.be/RaI3WYHSuWA
                          Frankford, Ont, Canada
                          613-398-6186
                          • mesmeridicus
                            • Sep 2013
                            • 74
                            • Dayton, Ohio
                            #118
                            Well, I'm trying to reassemble the rear wheel, hub, final drive, etc. and I've found that I cannot do so without the brake dragging on the rotor.
                            It's a Special. The wheel the original owner had on it was a 17", but he also gave me a 16". I put the 16" on seeing as it has a fresh tire on it, and a working wheel hub (splines are good). I thought I was missing a spacer, since the 17" and 16" have different parts, but I'm unsure. Most of what I've read said that the 16" wheel on a Special should not need an extra spacer. I currently have (as seen in the pictures) the dust hub/spacer thing, the brake bracket, and the other bracket attached to the brake. Stumped. Wondering whether the owner modified the rear wheel setup or whether perhaps his running the 17" without that spacer is what caused the final drive/wheel hub issue in the first place. Regardless, I need to fix this 16" wheel to the bike.
                            79 SF
                            • mesmeridicus
                              • Sep 2013
                              • 74
                              • Dayton, Ohio
                              #119
                              That is what my setup looks like. The dust hub/spacer, the and the two brake brackets.
                              79 SF
                              • mesmeridicus
                                • Sep 2013
                                • 74
                                • Dayton, Ohio
                                #120
                                http://www.boats.net/parts/search/Ya...EEL/parts.html
                                I believe that I am missing part number 23 in the diagram. That's my best guess.
                                79 SF
