Slight Ticking Noise After Head Replacement
  • D0wn5h1ft
    • Aug 2013
    • 515
    • Westerly, RI.
    Replaced my head because I bent the valves in the last one and now I'm getting a really annoying tick on the left side of the engine. It sounds like it's coming from the exhaust side of the head towards the top. I just put new exhaust gaskets in there so I can't imagine that it's an exhaust leak (because I know they sound a lot like a tick). When I went to put the head on I checked all the valve clearances and swapped the shims I needed to get it back into spec. The sound happens only on one cycle but I can't isolate which cycle it happens on. I pulled each spark plug to make sure it wasn't a detonation issue and the tick still persisted. If it was an exhaust leak I'd hear it regardless of whether the spark plug was in or not.
    Any ideas? Is there any way I can be sure it's not an exhaust leak?
    78 E - 2to1 exhaust, dynatek coils, special headlight [SOLD!]
    79 F - gas tank refurb, headgasket change, straight pipes, late model carbs, virago lowering shocks, special headlight and gauges, TC fuse block, GSXR-1100 carbs (WIP)
    "May my tires not fail me, nor my engine grow cold"
    • 3918
    Yup, tighten-down those flange nuts after the bike is at operating temp. The tick could also be just from the clearances being correct, and ur not used to it. I have noises on my bike that I cannot identify, yet not sure they're okay, but I ride the hell out of the bike, and it still runs.
    • D0wn5h1ft
      • Aug 2013
      • 515
      • Westerly, RI.
      That's the thing. It runs great but the tick is only on the left side. I guess it's just frustrating because I never had this issue with the old head.
      • D0wn5h1ft
        • Aug 2013
        • 515
        • Westerly, RI.
        I got on those header bolts good and the tick is gone. Thanks.
          FWIW, a little smear of high-temp grey silicone holds them in place and seals any non-comforming spot. Any removal later on, and one of those cushy purple abrasive pads for end of a Dremel remove the silicone and polish that recess area clean for the next header install.
          • D0wn5h1ft
            • Aug 2013
            • 515
            • Westerly, RI.
            And by header I mean the head nuts
              • 3918
              I remember when I first got my 750 ready to go and was trying to install that heavy header pipe and keep those gaskets in-place. Sooooo frustrating. U get the pipes in-place and don't realize one of the flanges fell down the pipe and the frame downtube prevents it from sliding back up. Take it back off, bring the flange back up, gasket falls out. I think I used rope caulk to hold 'em in, then used rope caulk at another point on-top of old gaskets, lol. When I got my 11, I saw Moto's tip with the grease, and those gaskets have never been an issue. However, I have yet to buy a set that had the adhesive backing that some have talked about.
                • 2066
                Gabe: Glad to hear you found the HEAD GASKET was leaking and it and was so easy to fix.
                • D0wn5h1ft
                  • Aug 2013
                  • 515
                  • Westerly, RI.
                  After riding today I found that it has come back a bit. It only appears once the bike is warm which leads me to believe one of my valves has too much clearance. I know the shop I only had a 270 to swap when I really needed a 275 so I think that is it. Warm oil is thinner and thus I think that is why it only starts once the bike is hot.
                  • MPittma100
                    • Aug 2011
                    • 2359
                    Tick
                    If tightening the header nuts made it go away, I suspect that you will need to replace the gaskets.
                    A few thousandths of an inch valve lash is not going to necessarily cause this noise.
                    Mike
                    1981 XS1100H Venturer
                    K&N Air Filter
                    ACCT
                    Custom Paint by Deitz
                    Geezer Rectifier/Regulator
                    Stebel Nautilus Horn
                    EBC Front Rotors
                    Limie Accent Moves On In 2015
                    Mike
                    • D0wn5h1ft
                      • Aug 2013
                      • 515
                      • Westerly, RI.
                      Mike
                      I though tightening the head gasket is what did it but it was actually just me letting it cool down before turning it back on again (engine was too got at the time to get in there with a ratchet). The head gasket is brand spanking new and there are no signs of leaking anywhere so it was just a coincidence that made me think that.
                      My clearance on the number #3 exhaust lifter is too high and I knew that putting it back together. I just didn't expect it to make that much noise. The clearance is at .12 when it should be .8 - .10 so I guess it's my fault for hoping it'd be fine. Is there any potential harm that can come to the lifter or cam with it being out of spec that little bit? I know these valves beat themselves into the head so theoretically it should go away with time.
                        • 8796
                        I wouldn't worry too much about a slight ticking, I'm running a head that has 130K+ miles on it and has a slight tick I can't get rid of, It's been doing it for years and many miles now. Takes a licking but keeps on ticking. GL
                        Edit: Possible the cam lobe is worn a bit, any debris in the oil tends to first attack the lobes for Cyl. #1, that is where the oil pools from bike sitting on the side stand.
                        • D0wn5h1ft
                          • Aug 2013
                          • 515
                          • Westerly, RI.
                          The cams came out of my old head that never ticked...hmmm. When I'm all moved in my place I'll see if I can't swap that 270 shim in for a 275. I'm still not sure if .12 clearance on the exhaust would cause a tick but who knows.
                          Correction: when I said #3 I meant #2 exhaust valve
                          • mack
                            • 2411
                            • Ontario, Canada
                            clearances
                            When the clearances are in the correct range, these motors are noisy. They are suposed to be. It is annoying if you have a fairing but I listen to mine and it lets me know that everything is in spec. When it gets quite is when you worry. Just like having kids.
                            mack
                            79 XS 1100 SF Special
                            HERMES
                            original owner
                            81 XS 1100 LH MNS
                            SPICA
                            78 XS 11E
                            IOTA
                            https://youtu.be/wB5Jfbp6SUc
                            https://youtu.be/RaI3WYHSuWA
                            Frankford, Ont, Canada
                            613-398-6186
                              • 9980
                              When I adjusted the valves on my SF it sounded like it was going to fly apart any minute. The thing ran like a raped ape.
                              Rode it to Wisconsin and back before I sold it. I figure about 2000 miles including the rides during the rally. Never even hiccupped.
                              BTW, you get lousy gas mileage at 90 or 100 MPH.
