New tire rear wheel to far left
  • donebysunday
    • Oct 2012
    • 1737
    • New Berlin, Wi.
    OH Yeah ! Thanks Greg !
    Got to check that out.
    I'm going for a little ride to see if there is a chance it feels different ?
    Done
    Quote from BA80
    Take the seat off and possibly the rear fender and do some eye balling and maybe some measuring. Verify that it is bent before going any further.
    It would take a pretty good hit to bend it however I've seen it before.
    This is RockinD's frame we swapped out on his SG. Notice how the rear part of the frame is bent down.
    76 XS650 C ROADSTER
    80 XS650 G Special II
    https://ibb.co/album/icbGgF
    80 XS 1100 SG
    81 XS 1100LH/SH DARKHORSE
    https://tinyurl.com/k6nzvtw
    AKA; Don'e, UD, Unca Don'e
      • 9980
      I was back looking at the pics of your tire being off center Done, if you look at the mufflers and the spacing between the fender it looks like it is bent. Unless your mufflers are that far off center.
      It actually looks like that left muffler is closer to the tire than the right but the fender spacing is wider.
        • 8051
        Could it be a bent fender?
          • 9980
          That was my first thought too Marty but it would be noticeably deformed pushed over that far I would think.
          • donebysunday
            • Oct 2012
            • 1737
            • New Berlin, Wi.
            Yes muffs tend to move around a bit.
            Yes the fender is a bit tweaked to the rt..
            Noticed the passenger grab rail has a worn down spot on the upper left corner, pretty good one too.
            But all that does not account for the amount of off center of the tire compared to the rest of the bike, except for the worn down spot on the grab bar, might be a clue as to what the bikes been through. Concerning the possible bend in the rear upper frame rails.
            Did just take it through the curves and feels fine.
            76 XS650 C ROADSTER
            80 XS 1100 SG
              • 9980
              That part of the frame being bent won't affect the handling, fortunately.
              Hopefully it's just the fender.
              • TomB
                • Aug 2006
                • 967
                • Cumbria, UK
                Try two straight edges either side of front and rear wheels, tell for sure that way.
                +1 on the bent rear fender
                Tom
                • donebysunday
                  • Oct 2012
                  • 1737
                  • New Berlin, Wi.
                  Have not had a chance to check the frame, just took a look with the seat off and other than a little paint chip next to the weld that holds the rear upper frame I can't tell if it's bent, that chip might be a clue ?
                  Don't know if I should call The Shop or buy a long straight bit of steel to check the front to rear wheel alignment.
                  76 XS650 C ROADSTER
                  80 XS 1100 SG
                  • Rasputin
                    • 3192
                    • Lacombe, Alberta, Canada
                    +1 one what Tom says. Do a straight edge off the wheels to see if they are aligned. You can also be creative and sprinkle flour or something on the ground and roll it thru that to see the tracking of the rear wheel after the front wheel passes thru. That will tell you if the wheels are aligned or not. If the swingarm is properly set and every spacer is accounted for then you may have a bent frame.
                    2-79 XS1100 SF
                    2-78 XS1100 E Best bike Ever
                    • donebysunday
                      • Oct 2012
                      • 1737
                      • New Berlin, Wi.
                      If the swingarm is properly set and every spacer is accounted for then you may have a bent frame. Thank You Rasputin !
                      Well this bike has been through much, just found this $79.95 engraved on the middle gear housing ?
                      Still need to check alignment etc.
                      76 XS650 C ROADSTER
                      80 XS 1100 SG
                      • donebysunday
                        • Oct 2012
                        • 1737
                        • New Berlin, Wi.
                        It was the seat rails, once everything was off the back it was easy to see.
                        Took a look at my just bought parts bike and checked align on it (good). Took measurements and used a 1X1/8" bit of aluminum to check both bikes. My seat rails were off 7/8". Used a 4X4 and a 3 1/2 lb. hand sledge and now it checks just fine and looks right. Checked all electrical connections greased them, all is well.
                        Thank You Everyone !!!!!
                        P.S. Checked the TCI (black box) from the parts bike and it fired my LH right up.
                        76 XS650 C ROADSTER
                        80 XS 1100 SG
                          Right on! I'm just glad you didn't lose the rear wheel spacer!
                            • 5069
                            FYI, Those seat rails can crack next to the factory welds.
