New tire rear wheel to far left
  • donebysunday
    • Oct 2012
    • 1737
    • New Berlin, Wi.
    XSives,
    I've done this many times never a problem.
    Put new tire on back and now wheel is almost 1" to far left ?
    IMPOSSIBLE !!!!! WTF ?
    Thanks ! Done
    76 XS650 C ROADSTER
    80 XS650 G Special II
    https://ibb.co/album/icbGgF
    80 XS 1100 SG
    81 XS 1100LH/SH DARKHORSE
    https://tinyurl.com/k6nzvtw
    AKA; Don'e, UD, Unca Don'e
    Might look around the man-cave for the missing spacer that escaped.
    • donebysunday
      • Oct 2012
      • 1737
      • New Berlin, Wi.
      If it was to the right, maybe.
      But this is to the left toward the differential, this should/can not be ? ? ?
      76 XS650 C ROADSTER
      80 XS 1100 SG
        Hmm, it can if you misplaced the spacer for the needle bearing.
        Did the bearing seal come out at any time while you were wrestling with the wheel? The seal holds the spacer in the hub next to the bearing and it will fall out if the seal is out of the wheel.
        Is the needle bearing center race still in place or is the axle riding on the bearing rollers?
          • 7785
          Maybe this will help.
            • 9980
            What is it that makes you think it's too far to the left? It slides into the final drive on the left and that's all. The only spacer is, as already mentioned, the inner race for the left bearing and unless the seal was removed it can't fall out.
            • Old Red
              • Jul 2012
              • 290
              • Greenville, NC
              What size tire are you running?
              The Other Earl
              80SG, 81SH, 80 standard parts bike, 81SH parts bike
              and new to me 78 standard dresser
              • donebysunday
                • Oct 2012
                • 1737
                • New Berlin, Wi.
                If I lost anything on the left side wouldn't the wheel be closer to the differential on that side ?
                Tire still clears the drive shaft housing, it's a 130/90/16.
                This is really noticeable, if had been this way with the other tire I'm sure it would have been seen and changed the aim of the steering.
                76 XS650 C ROADSTER
                80 XS 1100 SG
                  • 9980
                  Does it look like this Done?
                  Left side about a 1/4 inch.....
                  Right side about 2 inches........
                  • donebysunday
                    • Oct 2012
                    • 1737
                    • New Berlin, Wi.
                    Thank You Greg !
                    Yes, I'll get a pic of the alignment in the light. Had to take a break and rest my back.
                    76 XS650 C ROADSTER
                    80 XS 1100 SG
                      • 9980
                      Those pics I posted are the rear wheel correctly mounted on my SG. The left side of the tire is very close to the drive shaft tube while the right side there is about 1 3/4" between the tire and the swing arm. That's normal.
                      Being so close to the D/L tube is the reason it's difficult to run a wider tire on the rear like a lot of people would like to.
                      • donebysunday
                        • Oct 2012
                        • 1737
                        • New Berlin, Wi.
                        Here you can see how far to the left
                        Left side, notice how much tire is seen
                        Rt sd
                        Drive spline
                        What is causing this ? Thanks, Done
                        76 XS650 C ROADSTER
                        80 XS 1100 SG
                          • 9980
                          Everything looks correct at the wheel. Have you had the swing arm off? It looks like either the swing arm is way off center in the bearings or the rear part of the frame is bent.
                          • donebysunday
                            • Oct 2012
                            • 1737
                            • New Berlin, Wi.
                            Thanks again Greg !
                            Did not take swing arm off, is it just a matter of bearing wear ?
                            Seems it would take more wear than the bearing could allow to get this far off ?
                            Bike has 14K on the clock.
                            Seems it must be the upper rear frame ?
                            How to straighten the frame if it's bent ?
                            76 XS650 C ROADSTER
                            80 XS 1100 SG
                              • 9980
                              Take the seat off and possibly the rear fender and do some eye balling and maybe some measuring. Verify that it is bent before going any further.
                              It would take a pretty good hit to bend it however I've seen it before.
                              This is RockinD's frame we swapped out on his SG. Notice how the rear part of the frame is bent down.
                              He couldn't figure out why his rear wheel was rubbing the fender on bumps.
