Would the countershaft gear set assembly from a 1980 XS1100L MNS work in my 78 1100e?
Gunnery Sergeant, USMC (Retired), (A gung ho, lifer, Devil Dog) Semper Fidelis
XS1100E, 11.5" XV1100 shocks, "no name" 4 into 2 headers and turn out mufflers, stock air box, 140 mains, spade type fuse block, volt meter, LED conversion on running/turn/brake/tail lights, aux front driving and running light bar, 850 FD swap, Chrysler electronic VR. Ugly as a monkey's butt - runs like a scalded ape (WHEN IT RUNS)
Yes, it would!
โฌ
โฌ
Hi Clyde,
Be sure and look CLOSELY at those gear 'dogs' of the Midnite assembly. Even the slightest rounded ege on those dogs would be worth dis-assembly of gears from shaft and correcting before installation.
3Phase & motoman -- Many thanks for the input. There's a complete unit on Ebay for $30 plus shipping and I figured I'd clean it up (dremel) and swap it in. Thx. Clyde
Don't forget to swap the washer from one side of 2nd gear to the other.
