I can't get my carb's tuned properly with exhaust and pods. ):
The list changes. -
The list changes.Comment
81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
I didnt think so ):
Oh well, still need to fix um, and make that yics tool.
CURRENT PLAN OF ACTION:
Make yics tool,
wait for new jets to get here.
wait for lifter holder downer tool to get here haha,
that way I can get my shims out and see what sizes they currently are.
When the new jets get here, Im
'm gonna start with 1 over stock pilots and 4 over mains because that is what the chart says to do with my open exhaust and pods...
THEN I will install yics blockoff then vacuum sync carbs,
THEN tune pilot screws for highest idle
SOUND GOOD TO EVERYONE?!?!?!(:Have:
1994 FZR600
1982 XJ1100
Had:
1996 YZF600R
2001 Honda xr125
Suzuki race 80
Honda PW 50
Etc.
Getting:
1977 DT400Comment
UGHHH THIS DOESNT MAKE SENSE..
IF my exhaust valve clearance is measured at .005 (.127)
and I have a 215 shimm, IT TELLS ME TO GET A 225 SHIM.
THAT MAKES THE GAP SMALLER DOESN'T IT!>>?!?!
Because the shim is THICKER?
WTF I'm so frustrated right now... this doesn't make sense at all.Have:
1994 FZR600
1982 XJ1100
Had:
1996 YZF600R
2001 Honda xr125
Suzuki race 80
Honda PW 50
Etc.
Getting:
1977 DT400Comment
OMG I GET IT!!! It's not the cam lobe to lifter that is wearing.. it's gotta be the actual valve to the valve seat right? Those get worn and that makes the valve stem push up further this pushing the lifters up further into the cam lobe making the gap tighter>!?!?!?!
But still even them why would I want to make that gap even tighter with small bigger shims like the chart suggests?Have:
1994 FZR600
1982 XJ1100
Had:
1996 YZF600R
2001 Honda xr125
Suzuki race 80
Honda PW 50
Etc.
Getting:
1977 DT400Comment
I didnt think so ):
Make yics tool,
Turn the pilot screws for the highest VACUUM in each cylinder individually. They don't all have to be exactly the same because all the cylinders are different. Kinda like snowflakes if you know what I mean. Then resync and adjust the idle mixture screws again and resync....ect.....ect....until all cylinders are at highest possible vacuum and are in sync. You may have to make several passes. Keep the idle at about 800 to 1000 and about operating temp, let it cool if it gets too hotGreg
You have to get the feel for the valve adjusting tool and just catch the edge of the shim bucket or it'll drive you nuts.
This also a good time to blip throttle several times to seat threads of sync screws(you'll see the change after starting back up). Re-set....repeat till all four vacuums stay the same.
Turn the pilot screws for the highest VACUUM in each cylinder individually. They don't all have to be exactly the same because all the cylinders are different. Kinda like snowflakes if you know what I mean. Then resync and adjust the idle mixture screws again and resync....ect.....ect....until all cylinders are at highest possible vacuum and are in sync. You may have to make several passes. Keep the idle at about 800 to 1000 and about operating temp, let it cool if it gets too hotHave:
1994 FZR600
1982 XJ1100
Had:
1996 YZF600R
2001 Honda xr125
Suzuki race 80
Honda PW 50
Etc.
Getting:
1977 DT400Comment
Just a curious question, I just pulled the yics cover bolt thing on the left engine side... Oil dripped out, please tell me that is normal! ha...Have:
1994 FZR600
1982 XJ1100
Had:
1996 YZF600R
2001 Honda xr125
Suzuki race 80
Honda PW 50
Etc.
Getting:
1977 DT400Comment
