I can't get my carb's tuned properly with exhaust and pods. ):
  • If I go into throttle REALLY slow, it would raise rpm's to about 4k then stumble.
    OH and I just went and tried them at 2 cause I skipped that before... bike started only with choke (bike still pretty warm) then idled ok then just died all of a sudden... now it won't start at all..... WTF haha
    Have:
    1994 FZR600
    1982 XJ1100
    Had:
    1996 YZF600R
    2001 Honda xr125
    Suzuki race 80
    Honda PW 50
    Etc.
    Getting:
    1977 DT400
    • Make sure those 3 tiny holes behind the throttle plates on the top of the venturi are clean, clear and flowing and check your diaphragms for holes ( pinholes around the outer edge) and be sure they are seated in the groove under the cap where they are supposed to be.
      But GET THE RIGHT JETS IN THERE!!!!!!!
      • Also I'd like to know more about the pickup coils someone was referring to earlier.. I know where it is, I just don't know how to tell if anything is wrong.
        Have:
        1994 FZR600
        1982 XJ1100
        Had:
        1996 YZF600R
        2001 Honda xr125
        Suzuki race 80
        Honda PW 50
        Etc.
        Getting:
        1977 DT400
        • http://www.xs11.com/forum/forumdisplay.php?f=35
          • Originally posted by BA80 View Post
            I checked my diaphragms last week, and they looked good, I looked at them close up to a light bulb too.
            Waiting on all new jets too.
            Have:
            1994 FZR600
            1982 XJ1100
            Had:
            1996 YZF600R
            2001 Honda xr125
            Suzuki race 80
            Honda PW 50
            Etc.
            Getting:
            1977 DT400
            • My pickup coil setup (XJ11) looks much different than all the ones posted about, that I saw... :/
              Have:
              1994 FZR600
              1982 XJ1100
              Had:
              1996 YZF600R
              2001 Honda xr125
              Suzuki race 80
              Honda PW 50
              Etc.
              Getting:
              1977 DT400
              • There generally isn't a problem with the pickup coil wires on an XJ because there is no vacuum advance and the wires stay stationary.
                Do you have a vacuum line running from the nipple on the #2 carb, not the boot the carb, to the ignition vacuum sensor?
                • Originally posted by Dylano* View Post
                  I'm from Oklahoma and that's close enough to Missouri that you need to show me. How about a picture. I can imagine all kinds of things.
                  • Hey Dylano*,
                    Over a year ago I had stored my bike and forgotten to put Sea Foam in the tank/carbs, and they got gummed up. Bike would start but any attempts at giving it throttle only killed it. It wasn't getting enough fuel. Pulled and cleaned the carbs, and back to good as new. I'm not saying that you need to clean the carbs, just that the symptoms still seems like you're not getting enough fuel.
                    The Pickup coils info is in the tech tips, I just saw your request for this, and the way Greg is posting, he'll probably post the link to it before I get done with my reply! But just in case, here's the link:
                    http://www.xs11.com/forum/showthread.php?t=543
                    Anyways, addressing your non-starting bike now, if all you were able to do is get it IDLE and not get the RPMS above 2500, you have been DRAINING your battery, the charging circuit doesn't kick in well until ~2500 rpm or above, and so just idling, along with the repeated strains of STARTING the bike most likely weakened the battery just enough to drop it below the ~10.5 V threshold that is needed to activate the ignition system, and no start. You can test this by just jumping it with your car battery, if it then starts, then you need to put the battery on a charger for while....and while you wait, CLEAN The carbs!
                      It will look different because there is no vacuum or centrifugal advance on the XJ. It's all done electronically by the TCI. But, there is a vacuum sensor that needs to be hooked up. On this XV Virago I'm working on it's right by the coils and it's called a load sensor. I honestly don't know WHERE it is on an XJ but someone here does.
                      • Got the bike to start by putting petcocks to PRIME, instead of ON, and the fuel filters were full before I did this, and when I switched it to prime I was the ilters empty into the carbs and fill again...
                        the bike started but NOW
                        only the right side is firing, I'm getting COLD exhaust air out of the left bank.....
                        what is hooked up to the number 2 carb is called a BOOST SENSOR it says right on it
                        Have:
                        1994 FZR600
                        1982 XJ1100
                        Had:
                        1996 YZF600R
                        2001 Honda xr125
                        Suzuki race 80
                        Honda PW 50
                        Etc.
                        Getting:
                        1977 DT400
                        • Thanks TC. Dylan is asking questions and I've been doing my best to answer to the best of my knowledge but he needs an XJ guru here.
                            That's right, BOOST SENSOR. It has vacuum line and a 3 wire plug to it?
                              Yes, I believe that is correct.
                              Have:
                              1994 FZR600
                              1982 XJ1100
                              Had:
                              1996 YZF600R
                              2001 Honda xr125
                              Suzuki race 80
                              Honda PW 50
                              Etc.
                              Getting:
                              1977 DT400
                              • So I guess the NEW main problem is that it seems as if my left two cyl. aren't firing
                                Have:
                                1994 FZR600
                                1982 XJ1100
                                Had:
                                1996 YZF600R
                                2001 Honda xr125
                                Suzuki race 80
                                Honda PW 50
                                Etc.
                                Getting:
                                1977 DT400
