Bike Won't Crank
  • TheRev
    • Jun 2012
    • 235
    • Madison, Wi.
    Bike Won't Crank
    Hello
    I am having trouble with trying to start my bike. I have spent two years rebuilding everything. I installed the carbs today and have everything ready to start but when I hit the button I get nothing. So I think it must be a electrical issue. So I have a few questions I would like some help with. First off, where does this wire connect to?
    1979 xs1100f
    New Fuse Box
    Progressive Shocks
    Gold Valve Emulator
    Dyna Coils
    Electronic Flasher
    Led Headlight
    Led Turn Signals
    4 Led Driving Lights
    2nd Gear Fix
    Auto Cam Tensioner
    Digital Dash
    Stainless Braided Lines
    R6 4 Piston Calipers
    Stainless Bolt Kit
    Maier Fairing
    Dyna Balancing Beads
    Spin On Oil Filter
    Stebel Nautilus Horn
    Plasti Dip Rims
    ISO Grips
  • TheRev
    • Jun 2012
    • 235
    • Madison, Wi.
    Now when I use a screwdriver to short out the solenoid the starter kicks in like it should. Here is a pic of the two connections I shorted out.
    I suppose it doesn't matter since I took the entire bike apart but I did have it running before. Any help would be appreciated. Thanks
    1979 xs1100f
    New Fuse Box
    Progressive Shocks
    Gold Valve Emulator
    Dyna Coils
    Electronic Flasher
    Led Headlight
    Led Turn Signals
    2nd Gear Fix
    Auto Cam Tensioner
    Digital Dash
    Stainless Bolt Kit
    Maier Fairing
    Spin On Oil Filter
    Plasti Dip Rims
    ISO Grips
    • TheRev
      • Jun 2012
      • 235
      • Madison, Wi.
      Is there a way I can test the handle bar start button? Or is there a way to bypass it? Perhaps my problem is there.
      1979 xs1100f
      New Fuse Box
      Progressive Shocks
      Gold Valve Emulator
      Dyna Coils
      Electronic Flasher
      Led Headlight
      Led Turn Signals
      2nd Gear Fix
      Auto Cam Tensioner
      Digital Dash
      Stainless Bolt Kit
      Maier Fairing
      Spin On Oil Filter
      Plasti Dip Rims
      ISO Grips
      • mikubuilder
        • Jul 2011
        • 548
        • Westland, Mich.
        Hey Rev ,I don't have schematic at front of me, but I will try to help you anyway. The starter solenoid gets power straight from battery, low side of the coil is closed by blue wire grounded with starter button on right side control. ..so ,you have to check that you have power, and you do cause you can jump it with screwdriver. ..that usually points to connections in handlebar assembly. Check the plug between , it's close to steering neck...
        Nick
        1982 Virago 750 (it's alive!)
        • TheRev
          • Jun 2012
          • 235
          • Madison, Wi.
          Great suggestion. I went and checked the handlebar switch and it does have power. With your suggestion I found that the handle bar wasn't grounding the switch because I had powedercoated it. So I took the switch off, and made a jumper from a known ground point and I pressed the starter button at the same time I touched the ground wire to the metal inside the right control and it began cranking. YES!!
          So i turned on the gas in an attempt to start the sleepy beast and the gas spilled out of the pod filter. So my guess is that a float is stuck. Is there any way to test that without taking the carb apart? Also, how long should it take for the oil light to turn off when I am cranking the engine? Thanks
          1979 xs1100f
          New Fuse Box
          Progressive Shocks
          Gold Valve Emulator
          Dyna Coils
          Electronic Flasher
          Led Headlight
          Led Turn Signals
          2nd Gear Fix
          Auto Cam Tensioner
          Digital Dash
          Stainless Bolt Kit
          Maier Fairing
          Spin On Oil Filter
          Plasti Dip Rims
          ISO Grips
            Hard to tell from the pic Rev but that looks like the main power wire to the harness. With that disconnected you won't have power to anything.
            That wire should connect through the harness to the main power fuse.
            • TheRev
              • Jun 2012
              • 235
              • Madison, Wi.
              How should I make sure the handle bars are grounded? Apparently it is not making ground through the frame because of all the powder coating. Any suggestions.
              1979 xs1100f
              New Fuse Box
              Progressive Shocks
              Gold Valve Emulator
              Dyna Coils
              Electronic Flasher
              Led Headlight
              Led Turn Signals
              2nd Gear Fix
              Auto Cam Tensioner
              Digital Dash
              Stainless Bolt Kit
              Maier Fairing
              Spin On Oil Filter
              Plasti Dip Rims
              ISO Grips
                Grind the powder coating off down to bare metal at all the ground points. We had to do that with RockinD's frame too.
                  • 2117
                  Rev-take a screwdriver and take the handle of the screwdriver and whack the side of the carb that is leaking. That might free the stuck float. Happens quite a bit for some people. Sometimes the float hangs up on the carb gasket.
                    The earlier carbs seemed to be worse about if you let the carbs bowls get completely empty, it lets the floats/needles drop far enough down that the needles get cocked in the seat. If you have pods, you can shake the heck out of them up and down and see if that helps, but if you have fuel coming out the carb intake, then yes, that's some sort of float/needle/seat problem.
                      • 2117
                      And float needles are cheap on these bikes. They are $30.00 a piece on my ZRX.
                        I have 79 carbs on mine and every now and then they will flood. Bang on the bowl of the guilty carb and it might stop.
                        If not we cold send Ivan up there with his dead blow hammer. Hey, it worked on his.
                          Isn't that green wire the bypass wire to give full power to the coils durning cranking?
                          • TheRev
                            • Jun 2012
                            • 235
                            • Madison, Wi.
                            If it's the bypass wire then where does it go? It has a female bullet connector on it but I can't figure out where it connects to.
                            1979 xs1100f
                            New Fuse Box
                            Progressive Shocks
                            Gold Valve Emulator
                            Dyna Coils
                            Electronic Flasher
                            Led Headlight
                            Led Turn Signals
                            2nd Gear Fix
                            Auto Cam Tensioner
                            Digital Dash
                            Stainless Bolt Kit
                            Maier Fairing
                            Spin On Oil Filter
                            Plasti Dip Rims
                            ISO Grips
                              Here should be a wire coming out of the harness to connect it to. I think.
                              I don't have a bike or a wiring diagram to look at here at work.
