Bike Won't Crank
  • Filter
  • #16
    Originally posted by BA80 View Post
    Here should be a wire coming out of the harness to connect it to. I think.
    I don't have a bike or a wiring diagram to look at here at work.
    Now you do.
    http://webpages.charter.net/kbhahn/xs11/E-Fwire.JPG
    • #17
      Thanks CZ. If I am reading that diagram correctly, that wire should connect to a red/yellow wire in the harness leading to the TCI.
      That diagram doesn't separate the solenoid from the starter and doesn't show the connection between them. It looks in there that the battery cable that comes off the + connection of the starter just runs up ad connects to that red/yellow wire. Could be confusing to someone who isn't experienced.
      I wonder what other things on that diagram are unclear and confusing.
      • #18
        It is pretty though.
        • #19
          If it is not cranking at all though, that wire is not the problem. That green wire should not stop the starter from going.
          • #20
            Thank you so much. I will look for the red/yellow wire when I get back into town. It doesn't help that I am color blind as well. Do you have any idea where I am supposed to ground the handle bars. Everything was powedercoated and I would hate to start grinding where I don't need to.
            1979 xs1100f
            New Fuse Box
            Progressive Shocks
            Gold Valve Emulator
            Dyna Coils
            Electronic Flasher
            Led Headlight
            Led Turn Signals
            4 Led Driving Lights
            2nd Gear Fix
            Auto Cam Tensioner
            Digital Dash
            Stainless Braided Lines
            R6 4 Piston Calipers
            Stainless Bolt Kit
            Maier Fairing
            Dyna Balancing Beads
            Spin On Oil Filter
            Stebel Nautilus Horn
            Plasti Dip Rims
            ISO Grips
            • #21
              That right there is your problem! The '79 grounds through the bars. You are going to need to either run your own ground wire or start grinding.
              • #22
                That switch control grounds thru the bars. Remove and wrap a piece of emory cloth around that mount area and remove the paint. Never be seen, and should resolve your problem.
                • #23
                  I found a red with yellow stripe that wasn't hooked up. I had that marked as a "neutral switch". Is that where I should connect that green wire?
                  1979 xs1100f
                  New Fuse Box
                  Progressive Shocks
                  Gold Valve Emulator
                  Dyna Coils
                  Electronic Flasher
                  Led Headlight
                  Led Turn Signals
                  2nd Gear Fix
                  Auto Cam Tensioner
                  Digital Dash
                  Stainless Bolt Kit
                  Maier Fairing
                  Spin On Oil Filter
                  Plasti Dip Rims
                  ISO Grips
                  • #24
                    Went and looked at my SG and it does plug into a red w/yellow stripe wire on it. I would say that's where it goes Rev.
                    • #25
                      Thank you all for the help. I really appreciate this forum.
                      1979 xs1100f
                      New Fuse Box
                      Progressive Shocks
                      Gold Valve Emulator
                      Dyna Coils
                      Electronic Flasher
                      Led Headlight
                      Led Turn Signals
                      2nd Gear Fix
                      Auto Cam Tensioner
                      Digital Dash
                      Stainless Bolt Kit
                      Maier Fairing
                      Spin On Oil Filter
                      Plasti Dip Rims
                      ISO Grips
