Originally posted by natemoen
View Post
Vacuum Lines
Originally posted by BA80 View PostYou can use a test light as a makeshift oil light. Clip the test light lead to the connector on the oil sending unit and the other end to power. The light will be lit. If it goes out once the engine starts you have oil pressure.
When I start the bike the light doesn't go off. So I shut the bike off. Is there a way I can check to see if the oil is actually being pumped up from the pan? I think the oil is pumping but the test light doesn't go off.1979 xs1100f
New Fuse Box
Progressive Shocks
Gold Valve Emulator
Dyna Coils
Electronic Flasher
Led Headlight
Led Turn Signals
4 Led Driving Lights
2nd Gear Fix
Auto Cam Tensioner
Digital Dash
Stainless Braided Lines
R6 4 Piston Calipers
Stainless Bolt Kit
Maier Fairing
Dyna Balancing Beads
Spin On Oil Filter
Stebel Nautilus Horn
Plasti Dip Rims
ISO Grips
Are you touching the tip of the light to where the wire hooks the sender?Greg
Originally posted by BA80 View PostAre you touching the tip of the light to where the wire hooks the sender?1979 xs1100f
New Fuse Box
Progressive Shocks
Gold Valve Emulator
Dyna Coils
Electronic Flasher
Led Headlight
Led Turn Signals
2nd Gear Fix
Auto Cam Tensioner
Digital Dash
Stainless Bolt Kit
Maier Fairing
Spin On Oil Filter
Plasti Dip Rims
ISO Grips
How long did you let it run before you shut it down? It takes a while for the filter cup to fill.Greg
Originally posted by natemoen View PostThe standards do not have the octy, they have vacuum operated petcocks. There needs to be a vacuum line run from the forward facing nipple on the petcock to one of the nipples on the carb boot (usually left petcock to #2 boot and right petcock to #3 boot). You can cap the other 2 boots off.
Those boot nipples are where you hook up your sync tool. Those caps can be found at any auto parts store. They are just vacuum port caps.1981 XS1100H
Quando omni flunkus moritati
When all else fails, play dead.
Originally posted by BA80 View PostHow long did you let it run before you shut it down? It takes a while for the filter cup to fill.1979 xs1100f
New Fuse Box
Progressive Shocks
Gold Valve Emulator
Dyna Coils
Electronic Flasher
Led Headlight
Led Turn Signals
2nd Gear Fix
Auto Cam Tensioner
Digital Dash
Stainless Bolt Kit
Maier Fairing
Spin On Oil Filter
Plasti Dip Rims
ISO Grips
well, it only takes a few seconds for the filter to fill so I would guess that you either have no oil pressure or a bad sending unit.
You could take the sender out and crank the engine WITHOUT STARTING IT, just cranking. Disconnect the plug wires or something.
If oil squirts out the sender hole you have oil flow, just a bad sender. Might be a little messy but good for peace of mind.Greg
Originally posted by BA80 View Postwell, it only takes a few seconds for the filter to fill so I would guess that you either have no oil pressure or a bad sending unit.
If oil squirts out the sender hole you have oil flow, just a bad sender. Might be a little messy but good for peace of mind.1979 xs1100f
New Fuse Box
Progressive Shocks
Gold Valve Emulator
Dyna Coils
Electronic Flasher
Led Headlight
Led Turn Signals
2nd Gear Fix
Auto Cam Tensioner
Digital Dash
Stainless Bolt Kit
Maier Fairing
Spin On Oil Filter
Plasti Dip Rims
ISO Grips
I replaced mine when it went bad without taking the carbs off. It's not in there that tight. A good pair of pliers should loosen it and then just twist it out by hand.Greg
Originally posted by TexinMaine View PostI have a 78 and I am getting the carbs and tank cleaned. I noticed as I took the tank off there was a horizontal port on the petcocks that were not hooked to anything. Is this neccisary for proper function?Nathan
Vacuum Plugs
Originally posted by BA80 View PostThe OEM ones had spring clamps holding them on.
16G-13569-00-00 Plug, Blind (Rubber) $3.95. Boats.net shows none in stock.
Mike1981 XS1100H Venturer
K&N Air Filter
ACCT
Custom Paint by Deitz
Geezer Rectifier/Regulator
EBC Front Rotors
Limie Accent Moves On In 2015
Mike
Originally posted by MPittma100 View PostJust in case anyone wants to stay with the OEM plugs, here they are at NWVCP.com:
Mike
These little doodads are a bit pricey, but they're worth it. They take the heat and don't leak. They'll likely still be doing the job 20 years from now. I tried the cheap auto parts store option. They don't last long, then you have vacuum leaks and you wonder what's wrong with your bike.Marty (in Mississippi)
I immediately turned off the bike. I then pulled the spark plug wires off the plugs. Took the oil pressure sender off the bike and cranked the engine a couple of times. Oil spilled out of the oil pressure hole. Which means there is movement of the oil. Then I put the oil pressure sender back onto the engine and removed the banjo bolt at the top of the engine where the solid oil line is connected. I then cranked the engine and oil poured out of the solid oil line. This tells me that oil is making it up to the top of the engine.
So I assumed because the test light didn't go off when I started the engine that the oil sender is bad. Would that be correct? So I purchased another oil pressure sender and installed it today. I hooked up the test light the same way I did before and touched the pointy probe onto the screw at the top of the oil pressure sender and nothing happened. The test light didn't light up. Then I touched the pointy probe to the body of the oil pressure sender and it lit up.
So my question is this. Do I trust the new oil pressure sender? Does the light always go on when starting the engine and then go off once the engine is started after it builds up pressure?1979 xs1100f
New Fuse Box
Progressive Shocks
Gold Valve Emulator
Dyna Coils
Electronic Flasher
Led Headlight
Led Turn Signals
2nd Gear Fix
Auto Cam Tensioner
Digital Dash
Stainless Bolt Kit
Maier Fairing
Spin On Oil Filter
Plasti Dip Rims
ISO Grips
The oil pressure sender is nothing more than a ground switch. Without pressure to open it the light should stay on. When pressure is applied the switch opens and the light goes out.
If the light isn't lighting with the engine not running as you say then the new switch is bad I would say.Greg
