Vacuum Lines
    • 9980
    Originally posted by natemoen
    No, you need to have those uncapped so that you can hook your sync tool up to those.
    As long as you have a 4 guage setup. If your using 1 guage like some do (and I don't know how that could be anywhere near accurate) you need to plug them if the guage isn't hooked to them.
    • TheRev
      • Jun 2012
      • 235
      • Madison, Wi.
      Originally posted by BA80
      You can use a test light as a makeshift oil light. Clip the test light lead to the connector on the oil sending unit and the other end to power. The light will be lit. If it goes out once the engine starts you have oil pressure.
      Ok, I am not sure if I am doing this correctly. I take the clip on the tester light and connect it to power. Then I touch the pointed shaft onto the oil pressure sending unit. The test light becomes lit. Is that correct?
      When I start the bike the light doesn't go off. So I shut the bike off. Is there a way I can check to see if the oil is actually being pumped up from the pan? I think the oil is pumping but the test light doesn't go off.
      1979 xs1100f
      New Fuse Box
      Progressive Shocks
      Gold Valve Emulator
      Dyna Coils
      Electronic Flasher
      Led Headlight
      Led Turn Signals
      4 Led Driving Lights
      2nd Gear Fix
      Auto Cam Tensioner
      Digital Dash
      Stainless Braided Lines
      R6 4 Piston Calipers
      Stainless Bolt Kit
      Maier Fairing
      Dyna Balancing Beads
      Spin On Oil Filter
      Stebel Nautilus Horn
      Plasti Dip Rims
      ISO Grips
        • 9980
        Are you touching the tip of the light to where the wire hooks the sender?
        • TheRev
          • Jun 2012
          • 235
          • Madison, Wi.
          Yes. I am touching the tip to where the wire connects to the sender.
          1979 xs1100f
          New Fuse Box
          Progressive Shocks
          Gold Valve Emulator
          Dyna Coils
          Electronic Flasher
          Led Headlight
          Led Turn Signals
          2nd Gear Fix
          Auto Cam Tensioner
          Digital Dash
          Stainless Bolt Kit
          Maier Fairing
          Spin On Oil Filter
          Plasti Dip Rims
          ISO Grips
            • 9980
            How long did you let it run before you shut it down? It takes a while for the filter cup to fill.
            • TexinMaine
              • 160
              • Norway, maine
              The standards do not have the octy, they have vacuum operated petcocks. There needs to be a vacuum line run from the forward facing nipple on the petcock to one of the nipples on the carb boot (usually left petcock to #2 boot and right petcock to #3 boot). You can cap the other 2 boots off.
              Those boot nipples are where you hook up your sync tool. Those caps can be found at any auto parts store. They are just vacuum port caps.
              I have a 78 and I am getting the carbs and tank cleaned. I noticed as I took the tank off there was a horizontal port on the petcocks that were not hooked to anything. Is this neccisary for proper function?
              1981 XS1100H
              Quando omni flunkus moritati
              When all else fails, play dead.
              • TheRev
                • Jun 2012
                • 235
                • Madison, Wi.
                I only ran it for less than a minute. I was nervous i might mess the engine up. Although when I ran it I didn't hear any knocking.
                1979 xs1100f
                New Fuse Box
                Progressive Shocks
                Gold Valve Emulator
                Dyna Coils
                Electronic Flasher
                Led Headlight
                Led Turn Signals
                2nd Gear Fix
                Auto Cam Tensioner
                Digital Dash
                Stainless Bolt Kit
                Maier Fairing
                Spin On Oil Filter
                Plasti Dip Rims
                ISO Grips
                  • 9980
                  well, it only takes a few seconds for the filter to fill so I would guess that you either have no oil pressure or a bad sending unit.
                  You could take the sender out and crank the engine WITHOUT STARTING IT, just cranking. Disconnect the plug wires or something.
                  If oil squirts out the sender hole you have oil flow, just a bad sender. Might be a little messy but good for peace of mind.
                  • TheRev
                    • Jun 2012
                    • 235
                    • Madison, Wi.
                    Yes. I thought about doing it that way. I think that's what I will need to do. Now, I just have to get at it without take the carbs off.
                    1979 xs1100f
                    New Fuse Box
                    Progressive Shocks
                    Gold Valve Emulator
                    Dyna Coils
                    Electronic Flasher
                    Led Headlight
                    Led Turn Signals
                    2nd Gear Fix
                    Auto Cam Tensioner
                    Digital Dash
                    Stainless Bolt Kit
                    Maier Fairing
                    Spin On Oil Filter
                    Plasti Dip Rims
                    ISO Grips
                      • 9980
                      I replaced mine when it went bad without taking the carbs off. It's not in there that tight. A good pair of pliers should loosen it and then just twist it out by hand.
                        You need that vacuum port hooked up or else you need to run the petcocks on prime all the time for fuel to flow.
                        • MPittma100
                          • Aug 2011
                          • 2359
                          Vacuum Plugs
                          The OEM ones had spring clamps holding them on.
                          Just in case anyone wants to stay with the OEM plugs, here they are at NWVCP.com:
                          16G-13569-00-00 Plug, Blind (Rubber) $3.95. Boats.net shows none in stock.
                          Mike
                          1981 XS1100H Venturer
                          K&N Air Filter
                          ACCT
                          Custom Paint by Deitz
                          Geezer Rectifier/Regulator
                          EBC Front Rotors
                          Limie Accent Moves On In 2015
                          Mike
                            • 7941
                            Mike
                            $2.50 at Partzilla. 90467-11028-00 is the clip part number that holds them. Partzilla has those too.
                            These little doodads are a bit pricey, but they're worth it. They take the heat and don't leak. They'll likely still be doing the job 20 years from now. I tried the cheap auto parts store option. They don't last long, then you have vacuum leaks and you wonder what's wrong with your bike.
                            • TheRev
                              • Jun 2012
                              • 235
                              • Madison, Wi.
                              Ok, I am still having trouble with the oil pressure light. Here is what I did. I bought a test light. I clipped "the alligator clip" to the positive side of the battery and touched the pointy probe onto the screw on the oil pressure sender. The test light lit up. Then I started the bike and the test light stayed lit.
                              I immediately turned off the bike. I then pulled the spark plug wires off the plugs. Took the oil pressure sender off the bike and cranked the engine a couple of times. Oil spilled out of the oil pressure hole. Which means there is movement of the oil. Then I put the oil pressure sender back onto the engine and removed the banjo bolt at the top of the engine where the solid oil line is connected. I then cranked the engine and oil poured out of the solid oil line. This tells me that oil is making it up to the top of the engine.
                              So I assumed because the test light didn't go off when I started the engine that the oil sender is bad. Would that be correct? So I purchased another oil pressure sender and installed it today. I hooked up the test light the same way I did before and touched the pointy probe onto the screw at the top of the oil pressure sender and nothing happened. The test light didn't light up. Then I touched the pointy probe to the body of the oil pressure sender and it lit up.
                              So my question is this. Do I trust the new oil pressure sender? Does the light always go on when starting the engine and then go off once the engine is started after it builds up pressure?
                              1979 xs1100f
                              New Fuse Box
                              Progressive Shocks
                              Gold Valve Emulator
                              Dyna Coils
                              Electronic Flasher
                              Led Headlight
                              Led Turn Signals
                              2nd Gear Fix
                              Auto Cam Tensioner
                              Digital Dash
                              Stainless Bolt Kit
                              Maier Fairing
                              Spin On Oil Filter
                              Plasti Dip Rims
                              ISO Grips
                                • 9980
                                The oil pressure sender is nothing more than a ground switch. Without pressure to open it the light should stay on. When pressure is applied the switch opens and the light goes out.
                                If the light isn't lighting with the engine not running as you say then the new switch is bad I would say.
