Oil leak
  • ginger
    • Nov 2013
    • 29
    • Allendale, Mich.
    Oil leak
    So over the winter I replaced the seal on the crankshaft on the rightside, pretty easy fix, I thought. Took it for a ride today and came home with a shoe covered with oil. Kinda wondering what I diwrong, I tried to follow all the advise I found here,but...
    80 XS11
    Is the crankshaft seal leaking or the oil galley plug (right cover holds it in at the bottom) leaking?
    • ginger
      • Nov 2013
      • 29
      • Allendale, Mich.
      Oil Leak
      I haven't done the talc test yet but I'm 95% sure its still the crank, maybe I'll gat it pulled apart tonight.
      80 XS11
        Whatever you do don't start it with that right cover off or you'll blow that plug out across the shop.
        • ginger
          • Nov 2013
          • 29
          • Allendale, Mich.
          oil leak
          Thanks for the tip, i was thinking about trying that, if it looks like it is the plug, what is the repair procedure for that?
          80 XS11
            An O-ring.
            • ginger
              • Nov 2013
              • 29
              • Allendale, Mich.
              Oil Leak
              Does the plug just pull out, if I grabbed it with a vice grip?
              80 XS11
                It may not be that easy but yes, it will come right out. The alternator cover holds it in there.
                • ginger
                  • Nov 2013
                  • 29
                  • Allendale, Mich.
                  Oil Leak
                  So i got the plug right out, would it be advisable to get a little larger O ring and kinda force it in to seal it better, or just use the same size?
                  80 XS11
                    Is that what was leaking?
                    • ginger
                      • Nov 2013
                      • 29
                      • Allendale, Mich.
                      Oil Leak
                      I'm not sure but I thought I would try that before I rip the new seal apart that I just installed.
                      80 XS11
                      • ginger
                        • Nov 2013
                        • 29
                        • Allendale, Mich.
                        oil leak
                        So i guess it was not the galley plug
                        I'm looking for some advice on how to end this leak, seal has been replaced with a stock seal from Yamaha, any other options?
                        80 XS11
                          I'm wondering how you got an OEM seal back in there without splitting the cases. From my understanding the OEM seal has a lip on the outside that fits into a groove in the case.
                            • 4015
                            Yes Greg, you're correct. I'm curious too.
                            • ginger
                              • Nov 2013
                              • 29
                              • Allendale, Mich.
                              Oil Leak
                              My understanding is the left side seal has a lip, the right does not, I'm working on the right side, thats why I got the factory seal from Yamaha, I just picked the old one out with a small screw driver and some caution so as not to hurt the shaft( possible small damage to the cases but very minimal), then i just drove it in gently with a piece of PVC pipe the same size
                              80 XS11
