Potential new project
At first I thought it was the piece to the battery strap, but that's a solid bar. It really does not look familiar.1979 XS1100F
I never would have guessed that! Mine does not have those things!Nathan
Originally posted by natemoen View PostI never would have guessed that! Mine does not have those things!Marty (in Mississippi)
Originally posted by jetmechmarty View PostI believe it goes on one side and not the other. Mine turned up missing when I let somebody else work on my bike.XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.
Originally posted by natemoen View PostI never would have guessed that! Mine does not have those things!XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.
Getting there
Here's a few pix, folks. The project is now mobile, which makes things easier.
I found some 8mm wide stainless pipe clips on the internet. They are only large Jubilee type clips but they have a large area without the drive thread, so look OK, especially when polished with a buffer. OEM ones are still available but at approx $10 each and only mild steel, so I'm not bothering with those....
As things stand at the moment, the bike looks as per the pix. The brakes work. I've tested all the electrics apart from the charging side and everything works 100%. There's oil in the engine and I've turned the engine with the starter to pump it round..the oil light goes off after several turns, so pressure seems fine. I also loosened the banjo on the to do the oil feed pipe to the cylinder head and oil splurged out when the engine was turned.....
The next job is to get the carbs back on. I'm waiting for the CT1 sealer to harden on the O-ring fix on the carb tees, then I should be ready to connect the carbs up to the tank (all done off the bike) to check for leaks.
Then it will be ignition system time. I've not actually connected up the coils yet and have left the TCI disconnected for the moment. I ordered some bullet terminals to connect the coils up with and am waiting for those to arrive......
Onwards and upwards. I just hope the danged thing works at the end of all this!!XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.
I hope whatever you coated the O-rings with in the above pic doesn't decide to come loose, could leave a big mess in the carbs, just saying. Bike looks great BTW.2H7 (79) owned since '89
Originally posted by bikerphil View PostI hope whatever you coated the O-rings with in the above pic doesn't decide to come loose, could leave a big mess in the carbs, just saying. Bike looks great BTW.XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.
Ok then James, if you trust it then thats ok. Myself, I've never trusted any bonding chemicals that are exposed to fuel, even fuel vapors. I've never had much luck with that.2H7 (79) owned since '89
Petcock rebuild and carb testing
I got the two petcocks cleaned and found that the internals were all fine, so I didn't need the rebuild kits which are so readily available on eBay. I did replace the screws on the petcocks with stainless Allen bolts and countersunk screws.....
It's only a small detail but they tend to add up. One rusty screw can spoil things....
I connected up the bank of carbs to the fuel tank , off the bike, and found a sticking float valve which instantly flooded fuel,out through the carb mouth. Annoying, given that I replaced all the seats and needles but better to discover it with the carbs off the bike. So a bit off attention to #2 carb tomorrow!
Onwards and upwards....XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.
